Auto transmission shift problem...
Old Jun 23, 2001 | 07:22 AM
lt dan's Avatar
lt dan
1970 F250 360 w/auto transmission, and it runs GOOD, but it does not want to shift into 2ND gear after accelerating from stand still. If I let off on throttle and then accelerate again it will shift. Have checked vacum hoses and fluid level and they appear to be OK. Any suggestions on what the problem may be would be appreciated. Is this the way it is supposed to be?
I do not want to tear down the transmission.
Old Jun 23, 2001 | 10:11 AM
dynamic's Avatar
dynamic
im not sure what it is called ,, but, i think your problem is the part that is on the tranny that the vacum line leads to , I would look into that. also , might want to check your kickdown cable , never know ,,
Old Jun 23, 2001 | 06:35 PM
Bill_s351's Avatar
Bill_s351
Sounds like the modulator valve is shot Dan. There are adjustable modualtor valves made so that you can select your shift points. (1st to second @ 4500rpm etc.) You can adjust your shift points by turning the adjusting screw in in out. The screw is inside the end of the valve where you connect the vacum hose from the carb. After replacing that, it should cure your shifting problems.
Good luck,
Bill
Old Jun 26, 2001 | 08:02 AM
lt dan's Avatar
lt dan
Where is the modulator valve and how hard and expensive is it to replace?
Old Jun 26, 2001 | 09:49 AM
Bill_s351's Avatar
Bill_s351
The modulator valve is located on the passenger side in front of the pan. You can probably pick one up for about 10 or 15 dollars at any parts store. Good Luck!!!
Bill
Old Jun 26, 2001 | 10:44 AM
beartracks's Avatar
beartracks
I think it's on the right rear on the C-6 and held in with one bolt. Piece of cake.
1977 Ford F-100
400m/c6/4:11/Gear Vender O.D.
Crane hydralic roller, forged, ported polished,Deamon,Edlebrock, yada, yada, yada
280,000 miles
Stock on the outside
modified/rebuilt everything
Old Jun 26, 2001 | 10:46 AM
78f250's Avatar
78f250
