ECT closed loop temp
Old Jan 30, 2006 | 08:12 AM
puck1263's Avatar
puck1263
Anyone know what temp the computer needs to see from the ECT to go to closed looop? I'm having some undercooling issues.
The coolant hose on the TB split and sprayed anti-freeze everywhere. Didn't lose too much though. I pulled over within a minute. The hose was replaced and coolant filled up and bled. The spraying also fried my alternator, so I had to replace that too. Anyway, now the coolant temp on the gauge won't go up past the first bracket. I don't know what could be causing that. Maybe a chunk of something came loose and got stuck in the thermostat?
Old Jan 30, 2006 | 09:07 AM
subford's Avatar
subford
An engine can get very hot and the coolant temp gauge will not say so if it is not touching any coolant. Do not ask how I know.
I had anti-freeze take out an alternator and it also burnt a trace into on the back of the cluster.
Make sure the rest of your gauges are working OK.
Old Jan 30, 2006 | 09:14 AM
puck1263's Avatar
puck1263
where is the sensor for the gauge located? The connection may be loose...??
Old Jan 30, 2006 | 10:02 AM
subford's Avatar
subford
I do not know what engine you have but on a 5.0/5.8 it is between the Distributor and the Rocker Cover on the Drivers side. It is Number 67 in the Diagram. It also only has one wire on it.
Old Jan 30, 2006 | 06:28 PM
puck1263's Avatar
puck1263
well, the radiator shop used a laser to get temp readings off parts of my engine. Everything was as expected, so I'll have to get used to the new normal position on the gauge (which is between the bracket and the "n"...slightly closer to the bracket...it used to be on the "n" or between "n" and "o").
samsdad02
Apr 19, 2013 05:17 PM
airjeff
Nov 8, 2011 07:15 AM
azchris
May 19, 2011 03:03 PM
norm805
Aug 16, 2009 09:26 AM
MemOrex
Jan 23, 2005 07:22 PM
