Hissing noise
Old 01-19-2006, 08:22 PM
97F250LD4X's Avatar
97F250LD4X
97F250LD4X is offline
Hissing noise
I have noticed that everytime I stop my truck to get out of it and go inside my house or shopping,a hissing kind of noise is heard from the engine compartment. Its not exactly a hissing but sounds that way,like a motor of some sort is relieving pressure. Anyone else heard this? Could this be the AC system discharging.Or something else powering down? Its a 97 f 250 light duty 4x4 with a 5.4 liter. It does it all the time and I havent run the AC in a month. Im not too concerned but the noise puzzles me and I would like to Identify it . Thanks
Old 01-19-2006, 09:12 PM
JC947386's Avatar
JC947386
JC947386 is offline
If you are running your defrost or almost any other heater option your ac comp. does run and could be the noise you hear. Myne makes slight hissing noise when engine is shut off after running ac comp.
I also have a 97 f250lt 4x 5.4 that I have owned for 4 years. I have always thought it to be under powered. When in over drive at 65 it will barly speed up unless I down shift. What do you think of your trucks power. I also get 10MPG in town and 11.5MPG freeway, what does yours get?
Old 01-19-2006, 09:34 PM
97F250LD4X's Avatar
97F250LD4X
My truck does well, I installed a Banks Ram Air intake and it seems to have pepped it up a bit,on takeoff acceleration. I get about 16 hiway 14 city. I cant complain thus far. Im very happy with my truck.
Old 01-20-2006, 01:04 AM
Grsyhands's Avatar
Grsyhands
Grsyhands is offline
JC,
I've got a 4.2l V6 in my 97, 2wd. I know it's not the same but I was noticing a similar issue with it when I first put a rebuilt in it. I live in the north east and travel a lot of hills. My truck seemed way under powered until I changed my wires back to original motorcrafts. The power issue was improved even more when swapped out my slightly oversized summer tires for stock sized snows. Just a thought if you've changed any of these things. I also noticed the MPGs went up with the tire swap, even more than the size differential would have accounted for.
Old 01-22-2006, 10:22 AM
shane7209's Avatar
shane7209
shane7209 is offline
My F-150 4.6L makes the same noise, has done it since the day I got it. That was 150k ago, so I don't think it is a problem. For me anyway.
shark1979
04-26-2009 09:37 AM
TX76F250
1997-2006 Expedition & Navigator
15
12-10-2007 10:18 PM
serussell
03-04-2007 09:19 AM
SeannyBoy84
08-01-2005 12:12 AM
SeannyBoy84
07-27-2005 11:59 PM
Quick Reply: Hissing noise
