power window problem
Old Jan 18, 2006 | 06:04 PM
akfalconer's Avatar
akfalconer
My passenger power window is stuck in the down position.I took the door panel off and checked all connections.I can hear the motor clicking when I push
down on the switch, but no noise when I push up.do you think it may be the
motor or just the switch?2000 F350 SD.Thx
Old Jan 18, 2006 | 06:52 PM
oojbearoo's Avatar
oojbearoo
look and see wich wires run to the motor then jump them out (positive to one negative to the other) if that ,akes the window go down the reverse the negative and positive to the other wires if it dosnt go up then you got a bad motor if it does try the switch but it could also be a wire
Old Jan 18, 2006 | 07:22 PM
akfalconer's Avatar
akfalconer
Well,I'm still fooling with it.I took a couple peices off 12 guage wire and hooked it up directly to motor(using a portable battery jump box for power)and the window went up.So I guess I'll try to replace the switch first tomorrow.Thankyou
