Bronco II Ford Bronco II
Another power loss problem, code pulling problem.
Old Jan 1, 2006 | 05:52 PM
bronocIInoob's Avatar
bronocIInoob
Where is the air charge sensor
where is the air charge sensor at and how much dose one cost?? i pulled codes and i think mine sed it had bad volage readings from it and may need replacement
Old Jan 1, 2006 | 06:22 PM
Ken00's Avatar
Ken00
Passengers side of the intake manifold below the IAC.
Old Jan 3, 2006 | 11:53 AM
mrshorty's Avatar
mrshorty
KOEO and KOER ACT/ECT codes are common if the engine isn't properly warmed up before pulling codes. Make sure you've properly warmed the engine up before assuming the sensor is bad. Also, these sensors are basic thermistors (resistance is a function of temperature) and aren't hard to diagnose with a volt/ohm meter.
