please help
Old Dec 21, 2005 | 10:22 PM
mrbigdigits's Avatar
mrbigdigits
please help
i have a 91 mustang-sorry not a truck-2.3-will run smooth & all of a sudden ill loose #2 & 3 cyl,it comes & goes intermitt....i can pull a plug wire off coil pack & motor returns to running smooth when i make the spark jump....will be fine for awhile & then miss again...new plugs & wires,changed coil packs,new fuel filter,new injectors-i give!its gonna be a 302 soon so anything exp & its parked & pulled. t/y
Old Dec 21, 2005 | 11:05 PM
RangerPilot's Avatar
RangerPilot
Umm...if it's gonna be a 302 soon why bother honestly?
When you make the spark jump...I assume you mean grounding the plug and making it spark. It seems good? How much mileage is on this thing? All plugs and wires and packs are correct for the engine/year?
Old Dec 22, 2005 | 04:57 AM
mrbigdigits
i really need it to last bout 2 more months lol ...making the spark jump i mean pull the wire out of the coil pack just enough to hear & see the spark jumping from the coil pack to the plug end...thats when the motor starts running smooth again i had it happen on another car & it was the grounds-ive been over these grounds also-maybe missing one somewhere i dont se? hope this helps
Old Dec 22, 2005 | 05:13 AM
wendell borror's Avatar
wendell borror
[ Don"t Know Your Problem, But If Your Correct About The Ground. Ebay Has Ground Kits For Around 15.00, Something Like That, There Are Pretty Cheap. They Ground From The Battery To Several Locations In The Engine Bay. Easy Hook Up And Cheap Price Could Be Your Answer. Good Luck!!!!!!!!
