Need Help !!!code 0409
Old Dec 12, 2005 | 06:40 AM
riverrats007's Avatar
riverrats007
Exclamation Need Help !!!code 0409
I need some help. The check engine light came on in my 2001 sports trac a few weeks ago. I replaced the EGR valve and cleaned the lines out with carb cleaner. Once again the check engine light came. I took it to Auto Zone and had it checked the only code on it was 0409. The guy working there said it ment Flow Insuficent and it could be the egr cylinode. Does anybody have any clues on what I should replace first.
Thank You,
Collin Bond
