4x4 Problem
Old Nov 29, 2005 | 11:16 AM
4fords's Avatar
4fords
4x4 Problem
Hi all. Need some ideas on what could be causing a problem with my 4 wheel drive. Truck info is: 85 F150, 351 HO, C6. Left for work this morning with about 2 inches of snow on top of ice. Locked in the hubs and the second I started moving the truck began to shake and shimy. The faster I went the worse the shaking got. I also heard a clunking in what sounded like the front left. After about 2 blocks I stopped and unlocked the hubs, got back in and took off with no shaking or shimy. Any thoughts? Thanks in advance for you help.
Old Nov 29, 2005 | 12:04 PM
69 and 85's Avatar
69 and 85
I don't know thing 1 about 4wd, but if there's clunk'n and shak'n... I bet you can crawl under it and find some slop. Might have to jack it up and shake the axle or the tire. Seems like it's gotta be axle related or darn close!
Old Nov 29, 2005 | 12:47 PM
turbocoupe5.0's Avatar
turbocoupe5.0
U-joints? There are 5 u-joints in the front end of your 4 wheel drive. There is one at each front wheel, one in the middle of the front axle, one at the differential, and one at the front of the transfer case. Jack up the left front wheel only. Put the transfer case in 4wd and lock both front hubs. Crawl under the truck and rotate the left front tire back forth. While doing that, watch the u-joints for slop. This is easier with a helper. There will be a little slop in the differential gears, that's ok. The two yokes and the center section of each u-joint, however, should all turn at the same time with no noticable slop.
Old Nov 29, 2005 | 01:49 PM
4fords's Avatar
4fords
Would it shake like that even though I still have the truck in 2 high, the front end is just locked in? Could it be a bad lockout?
Old Nov 29, 2005 | 01:57 PM
Oval_obsessed's Avatar
Oval_obsessed
I had this problem once, it was that the transfer case shifter wasn't completely in 4H. I stopped and tried again and gave it a good pull and made sure it was in and no problem. You may also want to check your front driveshaft and see if the u-joints are ok.
Old Nov 29, 2005 | 02:07 PM
turbo2256's Avatar
turbo2256
Check the front axle u joints too. have had them rust from the inside out due to a distorted cap seal salt and water got inside. One of the few times a garage did some work for me.
Old Nov 29, 2005 | 05:22 PM
fordborn's Avatar
fordborn
Just to be sure, are the front tires and rear tires the same size? This can cause a vibration, shake and a clunk as the t-case gets loaded up and finally releases.
Old Nov 29, 2005 | 05:41 PM
smiller4597's Avatar
smiller4597
when you lock the hub the front drive shaft and axles turn whether the t-case is engaged or not. When you unlock the hubs the drive shaft and axles do not turn as long as the t-case is not engaged. sound like a u-joint to me. Hope its not in the t-case
Old Nov 29, 2005 | 05:47 PM
andym's Avatar
andym
My vote is for u-joint as well. smiller's explanation is right on.
kittyhawk
Nov 2, 2014 09:51 AM
mike bell
2004 - 2008 F150
Jun 5, 2012 08:41 PM
CA4X4smogsucks
May 18, 2012 07:42 PM
thbowen
15
Jul 1, 2009 01:55 PM
Fatsid
2004 - 2008 F150
30
Jun 7, 2004 05:41 AM
