Compression Test help 400
Old Nov 26, 2005 | 07:09 PM
78f250_rls's Avatar
78f250_rls
Smile Compression Test help 400
Just ran a Compression testdoes this numbers sound right
1 = 160
2 = 151
3 = 150
4 = 155
5 = 155
6 = 150
7 = 152
8 = 154
I was going to replace all the gaskets and the valve seats. Just want to make sure that I had good comp. so I didn't start blowing by the rings.
Thanks
Old Nov 27, 2005 | 01:40 AM
sparky69's Avatar
sparky69
it's hard to tell what the cylinder pressure should be. this can change from engine to engine due to cam timing. the best way to interpret these numbers is by comparing the highest reading with the lowest. you want the lowest pressure to be not less than 75% of the highest pressure recorded. your numbers are all pretty close to each other. don't think i'd even bother doing the math (but you can if you want). i'd say your in good shape.
Old Nov 27, 2005 | 05:58 AM
Greg 79 f150's Avatar
Greg 79 f150
My newly rebuilt 351m read 150 -152 psi on all cylinders. Those are good numbers. Sparky is dead on, I wouldnt worry about what isnt broken. If a person is seeing engine problems in the compression area though and wants the total test of valves, rings, etc, do a leakdown test also.
Old Nov 27, 2005 | 11:13 AM
78f250_rls's Avatar
78f250_rls
I am have some white smoke at start up and every once in awhile on accel. Do you think this good be from worn valve guide or seat?
Thanks
Old Nov 28, 2005 | 07:00 AM
danlee's Avatar
danlee
It is from worn valve guides or bad valve stem seals. You can inspect your valve stem seals to see if they are brittle or broken. They can also be replaced without removing the heads. Of course if you remove the heads for new seats the guides can be checked and seals replaced. From your compression test, I would just replace the seals 'on the motor', and leave the seats alone.
Old Nov 28, 2005 | 11:06 PM
go_racing84's Avatar
go_racing84
If it is solid white smoke, maybe it's a head gasket?
Edit... never mind, I guess that would show up on a compression test, wouldn't it...
Bakerderek0
Modular V8 (4.6L, 5.4L)
Jul 24, 2016 05:18 PM
green_95
Aug 17, 2015 02:34 PM
Huge Salad Fork
15
Mar 3, 2011 10:38 AM
todd jo
Oct 11, 2010 10:47 PM
02FX4Dude
15
Jul 6, 2005 11:27 AM
