How durable are the ttb front diff setups on an F250. I'm looking at a '97, cc,sb, 4x4, 460, manual trans, with stock tires. I'm not planning on any extreme wheeling, but I'm just not familiar with the ttb setup. One poster said the front end tends to wander and are difficult to keep tires from wearing out. Any other weaknesses or problems? Thanks.
For tires 35 and under (true for any dana 44 for that matter, but you should have the dana 50) the ttb is a good setup when used with coils, leafs springs don't move the same way as the ttb does and thus you notice the little quirks that the ttb is known for a bit better. But when you start having problems with keeping it aligned that means simply your springs and starting to sag, as far as the wander that means its probably just worn out tie rods or steering box (which can also lead to crappy tire wear as well), but for what you want to do you will see no problems.
on a mild wheeler with mild sized tires on a 250 you will be fine. the only thing you will have problems with is keeping the thing aligned. (as mustange so eloquently stated ) the leafs dont like the twisting forces that the TTB requires and this puts an excess strain on the leafs. coils on the other hand handle much better and can get away with a TTB setup much easier
One thing i should've mentioned that fishy remined me of, you should change out the spring eye bushings and the shackle bushing to a polyuthrane bushing, as with bigger tires and any amount of lift, the bushings tend to wear out way faster.
A TTB D44 and D50 are basically the same intenally except for slightly larger axle shafts. When you install big tires on a TTB you will not get good tire life because as you drive down the road abd the suspension flex the front tread or track width is constantly changing due to swing axle design which tends to erace the tread at a faster rate plus the chamber angle is constanly changing a lot which change the load centering on the tire. It will not fall apart but do not be surprized by driving and handling quirks and rapid tire wear on front axle. To really appreciate the difference, you need to drive a truck with 35's and a sold front axle and then the same on a TTB on varing road condition and you will see the difference in stability quickly.
Dana 50 has a 9" ring gear, bigger ujoints, and the bigger knuckles and dana 60 outers, good bit stronger where it counts i believe.
I have driven both and yes the solid axle will drive nicer, but unless you are doing so hard core wheeling where a 60 would be needed, i don't think its worth the expense, also the wheels should be traveling roughly the same amount as before when going down the highway as lifted coils are generally stiffer, so it should be roughly the same as before. again tire wear issues can be avoided if one keeps an eye out on the front end. Invest in a good stabilzer bar (with a quick disconnect), polyuthane bushings and dropped pitman arm (and a stabilzer bar would help), and you should have a decent handling truck if you decide to lift.
i have a 97 250 HD with 50 ttb up front, and for my wheeling, its been fine. but i don't do anything "extreme." but yes, you need to replace the front shackle bushings, i still need to do it, and i should have done it when i lifted the truck....the bushings are almost completely gone.
I use to have a 96 250 hd and the ttb and i never had any problems with it.I only used it in mudd and never on rocks though.I think you will be ok with it.
I have an 84 F150 4wd with a 2.5" suspension lift with the TTB front end. I am running 33" mudders, when I installed the lift kit I replaced all the bushings with polyurethane. I have all greaseable balljoints and tie rod ends, and I grease my front end at every oil change and I rotate my tires every oil change as well. I have been known to be harder on this truck than I probably should have. It has held up very well over the years, I have never broken any major components. TTB is plenty tough for me !
