A very good piece for basic theory. And I like the heat color table. The theory is right on.
Your description of the TIG setup might also include the coolant lines that help carry the tip heat away. In reading it, I also wondered if the newbie would know what the terms MIG and TIG meant. (MIG is "metal inert gas", TIG is "tungsten inert gas".)
There is also a context typo: "The easy way to prevent oxides is to preventedair from touching the surface of the pool. Thus, the weld pool is protected either by flux or a shielding gas."
I liked your way to explain how welding different thicknesses was like carrying a heavy suitcase in one hand.
Clint -
There is also a context typo: "prevented".
Thanks, Randy - all your suggestions were implemented and the copy now includes them.
There is another small typo.....The first sentance of the second paragraph...
(Metal (and all other mater) is very much the same).....
I think mater should be matter.
Man you guys are really kicking butt on the welding articles!! Excellent work!!
Yeah. Pictures of the "business end" of each weld equipment type like gas, stick, MIG, TIG in the welding position (with rod, etc) maybe ready to strike an arc would be cool. It would help illustrate the nerrative. They could be dropped in next to the description paragraph (you're good at that).
Pics of the weld puddle would be great, but I have never seen that done successfully because of the extreme light generated.
