is there anything wrong with pressure cleaning a diesel engine? should it be done with or without the engine running, and should anything be covered? thank you
So no pressure washer and engine should be cool.
I wash mine in the driveway. I spray some simple green on the parts that look oily(intake hose connections) and hose it off. If you have a pressure washer at home you can use it to squirt the block and tranny, just stay away from electrical components, intake, and other sensitive areas. I use my neighbors cuz he's an auto detailer and has a nice one.
steve
