Aerostar Ford Aerostar
Engine engage delay
Old Oct 31, 2005 | 09:14 PM
Matthew Letki's Avatar
Matthew Letki
Engine engage delay
Hi All,
My engine has a slight delay (1 or 2 seconds) when engaging after a hard stop. Is this an issue? It's fine otherwise.
Cheers,
Matt
Old Oct 31, 2005 | 09:35 PM
99f350sd's Avatar
99f350sd
Check tranny fluid.
Old Oct 31, 2005 | 10:08 PM
93nighthawk's Avatar
93nighthawk
What year is it? AWD? Engine?
If pre-96, then I would agree with 99f350sd, too low/high fluid. Also you might want to check out the modulator.
Old Oct 31, 2005 | 10:10 PM
Matthew Letki
It's a 96 RWD Shorty 3.0
Old Oct 31, 2005 | 10:13 PM
93nighthawk
So you have a 4r44e.....hhhmmm.... I would still check fluid level, no modulator to check.
Also are I would get the codes pulled and see if there is anything there. (sense the tranny is computer controlled.)
