1948-1960: 1949/1950 VIN # Cut off
#466
f 500 ford box truck
As suggested by George, the purpose of this thread is to try and determine what the VIN sequence # cut off is between the 1949 and 1950 Ford Trucks. It would also be a good opportunity to try and identify the VIN # cut-off for other little 1950 oddities like the raised panel bed being converted to a flat panel bed and the floor shift three speed versus column shift three speed.
Best way to do this is probably to ask for the following information:
1 - Year truck is registered as (or believed to be)
2 - VIN # (The whole thing including the 98RC, 98RD, etc.)
3 - Bed - Raised Panel or flat panel
4 - Is this the original bed
5 - Transmission
6 - Column shift or floor shift
7 - # stamped into the firewall if you have one.
?'s 3-6 may not be relavent if the truck has had major mods but if you know anything about what was there it would be helpful. I'll be sure to keep results updated. I need to figure out how to set up a link to the spreadsheet or data base I use.
Participation is obviously voluntary but would be greatly appreciated. Any other information on the truck you may want to provide would also be welcomed.
Sugggestions for other information to collect are also being welcomed.
Thanks,
Carl Gustafson - a.k.a Texan 2004
5 - Transmission
Thanks,
#467
hey tntroll, your best bet is to start a new thread asking about your truck, dont forget to post the VIN number.
name it 1960 f500 box truck info, or something in that nature, so people that have experience with those bigger trucks will reply. good luck.
there is also a vin decoder on the site, under the articles/specs tab.
#468
This site is so complicated ,all I wanted to know is if it was a 1ton or 2ton or what....this is one of the many times I have been refered to another post.Surely someone can answer this question sence all of you claim to be full blooded ford loving hard core ford people. I understand that this truck was built before most of you were born,however with the connections yuns must have,(BEING MEMBERS OF THIS SITE) someone can answer this simple question!! REMINDER (1960 F 500 FORD BOX TRUCK....1 TON..2 TON OR WHAT IS IT???)
#470
A 48-50 F5 was a 1-1/2 ton truck. I believe that changed when they went to the three digit F-series and the F-500 is a 2 Ton truck. Verify this. Do not take my word for it.
#471
Thanks Texan 2004!!
Thanks for the kind response,concidering I posted under the wrong thread,as I don't know my way around this site + I'am just a D****** country boy from the foothills of the smokey mtns. Some folks have'nt taken very kindly to me,but they will when I figure this site out. I am normaly a Chevy man but I stole this 1960 ford f500 box truck,now I'am in love!!! 390,12'box.tommy lift,etc Everything WORKS even the cig lighter.I just needed to find someone that knew something about it. The old man I got It from could'nt tell me if It was a 1 ton 2ton or what. None of the hicks around here knows anything + I have'nt found anything on the internet. Thank You for your response.....
#472
No problem. It's actually a very good site for questions.
One problem you are going to find is that the 57-60 trucks are sorta orphans. They are called refridgerator bodies because that's kinda what they look like. They are probably the least popular for restoration. That said, I must admit that I do like them even thought I opted for the 48-50 era.
Second problem you are going to have is that your truck is not a 1/2, 3/4, or 1-ton. The bigger trucks are not real popular but they do have a niche following. I have a couple of F-6's. The downside to the big trucks is that it is ahrder to find parts. The upside to the big trucks is that when you do find the parts, they are often in much better condition because they haven't been picked over yet because nobody could use the big body stuff.
Anyway, don't get frustrated. Play nice and you will make a few friends on here. Good luck with your truck.
#473
Thanks for the response, I have gotten more positive than negative from this site,and have learned alot. I undestand that this is not a desirable truck,It's kinda like an ugly puppy that's so ugly its AWSOME. What attracted me to this one is it's all there and most everthing works, besides one small rust hole in each front quarter panel,one side glass,and door handles, it's complete. It being undesirable makes it rare,most were used up and junked. It is worthy of some fresh paint and TLC,however the box has to go......
#474
F1s
Howdy,
My brother and I recently acquired a couple of F1s (Central Texas). Since they both seem to be produced late in their production years I thought they might be of interest to you.
His:
1-1949
2-98RC269211
3-Raised Panel
4-Probably the original bed
5-3 Speed
6-Floor Shift
7-LU44LL I 040K (Stamped backwards)
We think:
LU=Louisville
First 4=possibly Birch Grey (currently light green)
Second 4=possibly manufacture date
First L=November
Second L=? (maybe the guy got carried away)
I=? (and it is apparently a letter I)
040K (backwards)=?
Mine:
1-Unknown (probably very late 1950)
2-98RC490766
3-Flat Panel
5-tranmission and motor have been removed
6-Column Shift
7-DLM K16 122
DL=Dallas
M=possibly Mellow Green
K=October
16=Manufacture Date
122=unknown
Hopefully we're in the ball park.
Thanks,
bfc
His:
1-1949
2-98RC269211
3-Raised Panel
5-3 Speed
6-Floor Shift
We think:
LU=Louisville
First L=November
040K (backwards)=?
Mine:
2-98RC490766
3-Flat Panel
6-Column Shift
7-DLM K16 122
DL=Dallas
K=October
16=Manufacture Date
122=unknown
Thanks,
bfc
#475
on
no firewall stampings
Howdy texan 2004, question for you, i was talking to a friend that is currently restoring a 48 F1, he says the truck has no firewall stampings,
& i showed him on some old 48 to 50 cabs i have where that location is,
have you heard of this happening on the assembly line before ??
thanks, Jess
thanks, Jess
#476
thanks, Jess
thanks, Jess
There just wasn't a lot of consistency with stuff back then. Either from plant to plant or within the plants.
#477
Looks like you are in the ballpark but let's take a look at each one. BTW - Where are you in Central Texas??
See Below:
Curious about a couple of things on the second truck.
1 - Is there a hole for a floor shifter in the transmission cover?
2 - Do the rear fenders had the notch in them for the raised panel fenders or are they a flat fit against the bed along the entire interface?
I ask because VIN # 469536 (build date 9-21-50 in Dallas, TX) is located up the street from me. It has a flat side bed and column shift tranny but had nothces in the rear fenders for the raised panel bed and a hole in the tranny cover for a floor shift. That hole was covered over with some sort of non-standard metal patch.
See Below:
Howdy,
His:
1-1949
2-98RC269211
3-Raised Panel
5-3 Speed
6-Floor Shift
Looks like it is a late 49. The formatting of the firewall stamping on this one is rather peculiar.
We think:
LU=Louisville
Are you certain this is LU? While Ford did operate an assembly plant in Louisville at the time, I am not aware of any trucks being produced there. That does not mean they did not. It just means I have no record of it. If this is in fact a Louisville trcuk, it is a real oddball. LU was the 2-letter identifier for the Louisville plant.
I woulkd really like to get a photo of this firewall stamping if at all possible. (carl_w_gustafson at yahoo dot com)
Hard to say. There was a Palisades Green but I do not have a confirmed paint code for it.
Could be
First L=November
L is the correct letter for November
040K (backwards)=?
The rest of these are some sort of plant specific sequencing or coding numbers.
Mine:
1-Unknown (probably very late 1950) CORRECT
2-98RC490766
3-Flat Panel
6-Column Shift
7-DLM K16 122
DL=Dallas CORRECT
M=possibly Mellow Green CORRECT
K=October CORRECT
16=Manufacture Date CORRECT
122=unknown CORRECT
Thanks,
bfc
His:
1-1949
2-98RC269211
3-Raised Panel
5-3 Speed
6-Floor Shift
We think:
LU=Louisville
Could be
First L=November
040K (backwards)=?
Mine:
2-98RC490766
3-Flat Panel
6-Column Shift
7-DLM K16 122
DL=Dallas CORRECT
K=October CORRECT
122=unknown CORRECT
Thanks,
bfc
#478
#479
Thanks for the information on the two questions I had.
#480
F1s / LOU
Howdy,
Actually one of them was an F3. Page 26, this thread, #378 permalink posted by 49fordpickumup on 10-21-07. 49/50 F3 98RY392034 LOU.
Other was on Page 28, this thread, # 410 permalink posted by AK50 on 06-11-08. 50 F1 98RC322598 LOU.
Neither posting provided the stamped letters/numbers.
Sent you pics of the stamped letters/numbers that you asked for of the two F1s I orginally listed to your yahoo address. Hope you got them okay.
Thanks,
bfc
Thanks,
bfc
