1948-1960: 1949/1950 VIN # Cut off
Old 04-20-2006, 01:52 AM
BlueDolphin's Avatar
BlueDolphin
BlueDolphin is offline
I have not been on the forum for quite awhile. I will try to post all of my information soon.
My truck does have the non stamped bed sides. I also do not have the welded in radio brackets under my dash. This must be one of the trucks that used the strange faceplate on the radio. I am still trying to figure out a way of welding in the brackets or bolting them in... but I will wait to do that until I decide do a complete repaint of the truck. Then I won't worry about melting the paint when I weld the underdash, etc.. I have the column shift. I will have to think about other things I have found to be seemingly different, etc..
Anyway.... I will post all the numbers shortly
  #152
Old 04-20-2006, 07:36 AM
texan2004's Avatar
texan2004
texan2004 is offline
Looking forward to seeing what you have number-wise, especially with the column shift and flat-sided bed.
  #153
Old 04-20-2006, 10:09 AM
mtflat's Avatar
mtflat
mtflat is offline
Originally Posted by broncbustr
engine 9j-11096 model df83
trim 16 paint 22
serial df83h49 28842
this truck has f68 chrome on fenders chrome on grill and hood it has a full size box
unfortinatly for your studies that all i know of truck i bought it on a 77 frame
it is heavily modified not unfortunate for me
This website might help you decipher your Canadian vin. - Tim
http://www.mercury-pickup.net/19481951fordmercvin.htm
  #154
Old 04-20-2006, 10:09 PM
broncbustr's Avatar
broncbustr
broncbustr is offline
thanks mtflat but im so far from stock that it dont matter much to me where my truck came from i posted to help in vin searches as per requist in original post but thank you info is good
  #155
Old 04-20-2006, 11:38 PM
BlueDolphin
Here is my info:
1 - Year truck is registered as (or believed to be)
(1950 F1)
2 - VIN # (The whole thing including the 98RC, 98RD, etc.)
(98RC-478598)
3 - Bed - Raised Panel or flat panel
(Flat panels on bed)
4 - Is this the original bed
(I believe so)
5 - Transmission
(3 spd - Dana 41 rear)
6 - Column shift or floor shift
(Column shift)
7 - # stamped into the firewall if you have one.
(PBNR14 J98)
No underdash radio mounts.
Single wiper but has knockout for second one.
Single visor - but has knockout for second one.
Small rear window.
Original Flathead v8.
Tailgate top rail is thicker in center than outside edges (goes narrow to wide to narrow).
Did not have heater installed, but all the knockouts were in place for my install.
  #156
Old 04-21-2006, 10:13 AM
texan2004's Avatar
texan2004
Thank you for the reply. Your information is helpful, especially given the late build date, the column shift, and flat sided bed.
  #157
Old 04-25-2006, 07:52 PM
JimBenson41's Avatar
JimBenson41
JimBenson41 is offline
Thumbs up 1949/1950 VIN # Cut off
1 - 1950 F-1 late (or believed to be)
2 - VIN # 97HC313570
3 - Bed - Raised Panel see note below
4 - Not sure if original ""
5 - Trans 3 sp, 2,3 syncro
6 - Floor shift
7 - # PANR18 G64 On firewall above hood spring on driver's side.
Black
Possible late '50 since when installing wiring kit, gauges weren't exactly like manual layout and seemed to be cross between 50 and 51 schematic. Been too long to remember what exactly was different. Windshield wiper motor on driver side, dash braces cut/bent and had pass side wiper . Looks like late installation.
Rear axle, left front spring hangar was bolted to frame not rivet. Found when trying to figure why truck went down rd "sideways". too long of spring on left. Left wheel /axle must have hit something really hard but no visible fender bed damage so must have had bed replaced. Bed floor had thin wood planks under where two sheet metal layers had been welded to front and sides.
Sun visor on left side. Knockout on right.
Small rear window.
Heater was red so assume not original. (was in N.C.)
H226 flathead
Maybe too much info so delete if so desire. "Additional info" supplied in other replys was interesting to me but could be like elementary reading to others.
Not sure what the 8 +/- numbers on the data plate on firewall apply to but would they help? to you and all contributors. Jim Bob (old log in name)
  #158
Old 04-26-2006, 11:24 AM
texan2004's Avatar
texan2004
Jim,
Thanks for contributing. All oif the information is useful. Better too much than not enough.
Please feel free to ask any questions.
Carl G. - Texan2004
  #159
Old 05-03-2006, 08:39 PM
richard jobe's Avatar
richard jobe
richard jobe is offline
vin#S
carl
my vin# is 98rc506500 i got it from a farmers estate in la grange texas
it had a flatbed with side boards what can you tell about this truck
thanks richard jobe channelview,txx
  #160
Old 05-04-2006, 09:10 AM
texan2004's Avatar
texan2004
It's a 1950 F1 and a late one at that. It came with the Flathead V8 which is what you still have from our discussion. 506500 is the VIN sequence #. In my collection of nearly 200 VIN #'s, I only have one that is higher than yours (508885).
If you look on the firewall inside the engine compartment, there should be a serious of numbers stamped into it. These will tell you a bit more infomraion about the truck such as the date built and where it was built. MY guess is that your truck was built in Dallas but we can tell you for certain with the Firewall stampings. I would be real interested to get a look at yours since it is such a late build.
Just curious about your transmission. Is it a column shift or a floor shift? Which transmission do you have???
Look forward to meeting you soon.
Carl
  #161
Old 07-11-2006, 10:40 PM
wickkid's Avatar
wickkid
wickkid is offline
49, F-3 vin #
If your still interested in the F series vin #s. I have a 49 F-3 vin 97HY 311654 CS. I beleive it was origanally sold as a front end and chassis only to Boyertown Auto Body Works. They installed a Boyertown Step-N-Serve body, then turned it over to the US Post Office for mail service. In all they built 2500, bodies on Ford chassis for 1949. You can check out the truck in the article, "Neither Rain nor Sleet" by BobTomaine in the October 3rd issue of Autoweek. Thanks, WICKKID.
  #162
Old 07-12-2006, 08:15 AM
texan2004's Avatar
texan2004
Welcome to FTE and thank you for the information on your truck. Hope you stay around. there is a lot of great information to be had on these truck at thsi sight whether you'r bone stock or a hot-rodder (Dark Sider). Sounds like it's had an interesting histrory. I have a few additional questions if you don't mind.
1 - Is the truck in Hawaii and ahs it always been?
2 - What year October 3 Issue of Autoweek?
3 - Does your truck have the small rear window (vs. the larger rear window that appeared on the 1951/52 trucks)?
4 - Does/did your truck a floor shift transmission or a column shift?
5 - What engine are you running? the original six or something else?
6 - Can you look inside the engine compartment for a serious of #'s and letters that may be stamped into the firewall? If you can locate them, we may be abe to give you the date the truck was built, where it was built (though it appears to have been in Chester, PA) and the original color.
Based on the VIN # you provided, I would say your truck is actually a 1950 model year truck and not a 1949. The original purpose of this thread was to identify the cut-off for VIN #'s between 1949 and 1950 (we are now out to debunk or confirm some other urban myths surrounding these trucks as well as determine/confirm the VIN # cut-offs for 1949/1950). Ford did not start over with new VIN #'s in 1950. They simply continued with the string from 1949. We do know that the cut-ff for 1949 six cylinder trucks was different than for 1949 V8 trucks but in both cases the cut-off occurred below VIN # 300,000. If you can find that number I asked for in item 6 above, we will likely be able to tell you what day the try was built.
Again, welcome to FTE and if you can figure out how to post picuteres in a gallery on here, we would love to see some photos of you truck.
  #163
Old 08-13-2006, 03:40 PM
Jammero's Avatar
Jammero
Jammero is offline
It looks like you are the go to guys for the information I need. I have an F-1
1. I don't know what it was registered as.
2. 98RC183109
3. Just looking at it, it looks flat to me.
4. I think so.
5. 3 spd.
6. Floor.
7. 2CH25DA582
Branch CGO
Any information you guys can give me will be greatly appreciated.
  #164
Old 08-13-2006, 04:05 PM
mtflat's Avatar
mtflat
mtflat is offline
Hi Jammero, looks like a '49 V8 half-ton. 183,109 is the serial number which began Jan 16, 1948 and ran thru Sept 15, 1951.
The firewall stamping is production code:
2 - Vermillion Red (is this right?)
CH - chicago assembly plant
25 - 25th
D - April Should only be one letter for the date.
A582 - any chance the A could be a 4? This numeric string is the unit/car number produced that day.
Branch number looks like Chicago abbrev
Carl's our official information guru - I was just stopping by. Enjoy your truck.
  #165
Old 08-13-2006, 04:31 PM
mtflat's Avatar
mtflat
mtflat is offline
Carl, I was wondering................
Prior to Jan 16, '48 when the Bonus Built trucks debuted, I've heard the 48's looked just like the 46/47's. In your collection of vins are any of them designated as 899C's (which they should have been if they exist)?
Also, on the Old Ford Truck Club for 1950 models they state that 148,956 50's were sold. Assuming (I know) that 1949 sold 170,000 trucks and we know '48 saw sales of under 166,000 - totalled together I get around 485,000.
What do we know about the the 50/51 model break? Was it similar to 47/48? The new vin and body style supposedly began Sept 15, '51.
Are the trucks we're calling 50's over 485K actually 51's that look like 50's as Ford continued to use up old sheetmetal?
Any thoughts or information, Carl or anybody?
Quick Reply: 1948-1960: 1949/1950 VIN # Cut off
