1948-1960: 1949/1950 VIN # Cut off
Old 10-09-2017, 08:50 PM
Moe Craig's Avatar
Moe Craig
Moe Craig is offline
I read it as 2 DL D 11 over 2012
2 = Vermillion Red
DL = Dallas, TX
D = April
11 = 11th
(birthday of April 11, 1949)
2012 = ?
Sorry everyone didn't remember that I already posted this info!
Originally Posted by Moe Craig
1 - Year truck is registered as (or believed to be) 1949
2 - VIN # (The whole thing) Frame - 98RC179143
Pattent plate - 98RC179143 DAL
3 - Bed - Raised Panel or flat panel - Raised
4 - Is this the original bed - Believe so
5 - Transmission - Gone
6 - Column shift or floor shift- Column
7 - # stamped into the firewall if you have one.- somethings there but haven't figured it out yet...
Last edited by Moe Craig; 10-09-2017 at 09:06 PM. Reason: Sorry everyone didn't remember that I already posted this info!
  #1142
Old 10-09-2017, 09:05 PM
harleymsn's Avatar
harleymsn
harleymsn is offline
the funny thing to me is that Bobbytnm (found his info on post #35) was born after mine by a month but his last 4 numbers are 1008 lower than mine.
Moe, the reason for that is that Ford issued the serial numbers out of headquarters to each plant in batches.
  #1143
Old 03-03-2018, 06:03 PM
acl9865's Avatar
acl9865
acl9865 is offline
Anyone confirm that this serial # looks original and not altered?
  #1144
Old 03-03-2018, 07:15 PM
49fordv8f4's Avatar
49fordv8f4
49fordv8f4 is offline
The R and T look odd, but I believe they are original. 1949 or 1950 V8 F4
Mark
  #1145
Old 03-03-2018, 09:16 PM
acl9865's Avatar
acl9865
acl9865 is offline
Mark
And yet it's a 1950 S6 F4 =(
  #1146
Old 03-03-2018, 10:51 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
With a production number that high, I'd be confident about it being a '50. As far as the V8 vs. 6, can't help you there...
  #1147
Old 03-03-2018, 11:21 PM
mtflat's Avatar
mtflat
mtflat is offline
I agree with what Mark and Ross have posted.
What does the tag on the firewall and glovebox door indicate - same numbers?
What side is the battery located on? V8 and I6 were opposite.
  #1148
Old 03-04-2018, 09:17 AM
acl9865's Avatar
acl9865
acl9865 is offline
Numbers match, battery is on drivers side.
  #1149
Old 03-04-2018, 03:13 PM
mtflat's Avatar
mtflat
mtflat is offline
Interesting - the R and T are a bit different, but no evidence whatever of being altered. While it's the exception to the rule, there are a lot of exceptions out there...
  #1150
Old 03-04-2018, 07:23 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Then it really was a 6-banger from the factory.
  #1151
Old 03-11-2018, 10:23 PM
Fiveflat's Avatar
Fiveflat
Fiveflat is offline
Hello folks,
I hate to just throw my numbers out there and just ask for a translation. I scoured through this thread and figured most of it out but I still have questions. Please correct me if I'm wrong:
My vin is:
97HC315466 * RIC
9: 1950
7H: 6 cylinder
C: 1/2 ton (F-1)
315xxx: early 1950 (3-speed on the floor)
RIC: Richmond, California? or is that Virginia?
Now my biggest question is regarding the firewall stamp.
From what I'm understanding is RH (RIC on the VIN) is for Richmond (still not clear if that means California or Virginia)
As for the rest of it, I'm at a loss. I don't know what is the paint code (it's been painted over a couple times) or the manf. date. I'm primarily trying to figure out the real paint code...
. I
And here it is, with this lousy faux rust paint, right over the little bit of patina (rust haha) it once had (and still does):
(and fake white walls)
  #1152
Old 03-12-2018, 12:38 AM
Moe Craig's Avatar
Moe Craig
Originally Posted by Fiveflat
Hello folks,
My vin is:
97HC315466 * RIC
9: 1950
7H: 6 cylinder
C: 1/2 ton (F-1)
. I
You have a truck that was built in Richmond, CA, Painted Sheridan Blue, built on Tuesday, 9/6/1949 and 511 down the line.Sheridan Blue
  #1153
Old 03-12-2018, 09:36 AM
Fiveflat's Avatar
Fiveflat
Fiveflat is offline
Thank you very much! So those letter "I" are in fact number "1" I guess...
Can I ask you how you came up with Sheridan Blue? I only ask because I've sanded down beneath this red color and only found 2 very light colors, either a gray or dull blue-ish...
  #1154
Old 03-12-2018, 10:15 AM
Y-Block Limey's Avatar
Y-Block Limey
Y-Block Limey is offline
The Richmond thing threw me for quite a while too, at first. Mine's a '56 'R' code.
Several online sources seem to refer the 'R' or 'RH' codes to Richmond, VA. Since there doesn't appear to ever have been a Ford plant here (only Norfolk), it must refer to Richmond, CA.
When I looked mine up, it said Richmond VA, which then leads to Richmond CA, and neither of those are correct either because production moved from there to San Jose between '53 and '56. So my 'R' code is actually San Jose, CA.
Confused.com!
  #1155
Old 03-12-2018, 03:01 PM
Moe Craig's Avatar
Moe Craig
RH = Richmond
FI = 1/2 ton
S = Sheridan Blue
6J = 6th of Aug
5II = 511
If someone sees it different let me know.
Quick Reply: 1948-1960: 1949/1950 VIN # Cut off
