1948-1960: 1949/1950 VIN # Cut off
#1111
Thanks Brian
Is there any way we could see a picture of the firewall. There aren't many Buffalo built trucks in the database.
10 is color and I'm not sure if it was one of the grays (Dover) or beige?
BF would be Buffalo
88 ? not sure what that might be without seeing a picture
1J is in the right range for a Sept 1 build date
BF would be Buffalo
#1112
Here it is. I don't know the actual color. My dad thought green, most is a bleached tan like the firewall, but on the door frame and under a grommet I've spotted a maroon, which was one of the colors. But, this could be the primer and the real color has weathered off.
Here are the images... one in negative helps identify letters.
Also one of truck right before i put it in my garage after towing it 700 miles.
#1113
#1114
#1115
Yes, but don't read too much into those mid-year changes. Not every truck had column shift at that point, and it was only for the light-duty 3 speed trans. The 3 spd HD, 4 spd and all the others were still floor shift.
I've heard the same thing about box sides too, but have plenty of evidence to the contrary - the cutoff straggled along until '51 models. Ford tended to have assembly plants use up whatever left over stock was on hand before going to the new parts.
#1116
mtflat, You're right and as it turns out I have the HD 3 speed... only found that out when changing out gear oil and not having enough and then PMing one of the members (Albuq-F1). The HD was an option and always on floor from what I found. That also could be wrong though! I'm trying to figure out what the HD means for me, if anything.
#1117
I was also going to question the September date based on the earlier style bed (raised panels). My truck from May,'50 has the later 50-51 bed. Although the changeover varied by plant, it would be my guess that by September most of the plants would have made the changeover. March looks correct to me.
#1118
#1119
The side panels of your bed are embossed with a raised center section. I assume this was to provide more rigidity to the panel. Sometime mid-1950 this detail was eliminated and the side panels were made entirely flat. As a result, the rear fenders were also changed to eliminate the notch that was necessary to fit around the raised section.
#1120
Its much more rugged than the Light Duty 3 which was used in 48-50 F1''s. The column shift wasn't included until 1951 according to the shop manual.
#1122
#1124
#1125
1950 V8 Half-ton, serial number 410867
firewall:
P - I don't know, but Norfolk is the only assembly plant that included this extra letter
A - color Raven Black
NR - Norfolk, VA assembly plant
14F - assembled June 14, 1951 <probably> (Ford used this old serial string until Sept 15, 1951)
81 - vehicle down the line
