Glass Cleaner
Old 10-06-2005, 06:57 PM
Ranger Louie's Avatar
Ranger Louie
Ranger Louie is offline
Glass Cleaner
I need a good glass cleaner or galss polish that would remove Rain X residue and won't streak or haze.I've tried glass and surface cleaners to no avail.Can't seem to remove a haze from the windshield.
Old 10-07-2005, 06:29 PM
charlesh's Avatar
charlesh
charlesh is offline
IMHO, there is nothing better than Invisible Glass. Sells at most auto parts stores. Not sure about removing the rain-x residue.
Chip
Old 10-08-2005, 07:27 PM
mill666er's Avatar
mill666er
mill666er is offline
You might try goof-off or a professional wax and grease remover available at automotive paint suppliers.
Old 10-14-2005, 08:41 AM
77300i6's Avatar
77300i6
77300i6 is offline
On a sidenote, I use newspaper to wipe off the glass cleaner. It's usually already lying around and doesn't streak or leave fibers on the glass. You usually have to wipe off the ink that is now on your hand . No big deal though.
Old 10-29-2005, 07:01 PM
EscapeinWV's Avatar
EscapeinWV
EscapeinWV is offline
Invisible Glass (cheapest to buy would be WalMart) and Newspaper will do the job.
Old 10-30-2005, 01:04 AM
KenB's Avatar
KenB
KenB is offline
Ditto the Invisible Glass spray cleaner, best stuff I've ever found.
If you think you have a difficult slime or a super dirty situation, and want to do an extremely good cleaning before a 'finish cleaning' with Invisible Glass, you can use about a tablespoon of clear vinegar to a gallon of water, and the newspaper.
It helps to wad up the newspaper before wiping with it.
Old 10-30-2005, 05:45 AM
NitrousAl's Avatar
NitrousAl
NitrousAl is offline
Invisible Glass is great. The difference is night and day.
Old 11-15-2005, 12:59 PM
brents's Avatar
brents
brents is offline
Bon Ami is the only thing I will use on glass.
-Brent
Old 11-15-2005, 03:41 PM
MikeB 88's Avatar
MikeB 88
MikeB 88 is offline
I used a product called Glass scrub. Found it at O'Rielly Auto Parts. Cleaned the old Rain-X off plus filled in some small scratches. For every day cleaning I use Invisible Glass and a micromesh cloth made for glass. I'll use newspaper when the cloth is dirty.
Mike B
Old 11-15-2005, 10:48 PM
spidk43's Avatar
spidk43
spidk43 is offline
A note about small scratches... they can also be filled in with regular toothpaste-I'm talking about the white (color) kind of colgate or the crest original paste. I have used this trick a few times to fill in minor scratches on watch faces and such. take a small amount and rub over the scratch in a circular motion with your finger (or a cloth) and then finish wiping in one direction against the "grain" of the scratch with a cloth. I learned this trick from my mom, who is a dentist. Just another quick garage (or bathroom) fix.
~Matt
P.S. I have only done this with regualr paste (both colgate and crest) I think the results would be the same with most any solid colored toothpaste though.
Old 11-19-2005, 05:36 PM
berkad's Avatar
berkad
berkad is offline
Invisible glass in a product from a company called , of all things, STONER. Check them out they have GREAT products. www.stonersolutions.com
Old 11-24-2005, 06:31 PM
tomdoggie's Avatar
tomdoggie
tomdoggie is offline
Wish I owned stock , in invisable glass. Its great,
Old 12-04-2005, 11:53 PM
bigdaddyII's Avatar
bigdaddyII
bigdaddyII is offline
Invisible glass is great, bought a can wanting to try something new, never looked back, my wife even uses it around the house and has never even uttered the word windex since.
Old 06-03-2006, 09:46 AM
ALAN_50501's Avatar
ALAN_50501
ALAN_50501 is offline
Ditto the Invisible Glass spray cleaner, best stuff I've ever found. i just brought it last nite and im really happy with it..
Old 06-03-2006, 11:29 AM
charlesh's Avatar
charlesh
charlesh is offline
My second post here. Can't believe this thread is still around. It was stated by others and I just want to second it that before using Invisible Glass to make the windshild appear almost invisible, something else should be used to get the really ugly stuff off such as tree sap or whatnot. Invisible Glass doesn't work that great on the crusted stuff but is the best for the final cleaning.
