'91 Ford D-150 Nite Brake Problems
Old 11-13-2005, 08:52 AM
ashleydaryll's Avatar
ashleydaryll
ashleydaryll is offline
Exclamation '91 Ford D-150 Nite Brake Problems
My husband just recently purchased a '91 F-150 Nite that needed new brakes/rotars. He is running into some problems removing the old brakes, it seems like he needs some sort of allen key for it, but no sized allen key is working. does anyone know of a trick or if there is a certain tool he would need to purchase before he can remove them? Any help is greatly appreciated!
Old 11-13-2005, 08:55 AM
plapczynski's Avatar
plapczynski
plapczynski is offline
On my 93, they just hammer out. Do they have some rubber material in it? If so they should tap out with a drift and hammer.
Old 11-13-2005, 01:17 PM
andym's Avatar
andym
andym is offline
We need more detail.
Is this a 4x4 or 4x2? What part is he having trouble removing? The only place I can think of that he needs an alan key for is the removal of the hubs, but I just want to confirm that. If that's the case, he needs either a 9/32 or an 11/32 (can't remember which).
Old 11-13-2005, 01:31 PM
MikeGV's Avatar
MikeGV
MikeGV is offline
Brake Removal
I have a 91 F150 2WD. I've done the rotors before as well as the pads. I didn't use an allan key for the rotors (that I remember) and I know I didn't use one for the pads..they just have some sliding retainers that hammer out. They are like a 4" or so rod, but they are diamond shaped (not round). They hammer out with a drift or punch and have a rubber insulator between the two halves.
Its kind of like if you made a rod that looked like this on the end:
<> But there is a rubber insulator between the two ends.
Mike
Old 11-13-2005, 01:34 PM
quicklook2's Avatar
quicklook2
quicklook2 is offline
i'm with andym, we need more info.
the more you describe your problem and vehicle specs the better members can help you.
do you have a manual? if not get one.
dhearn
12-23-2018 06:35 PM
dustybumpers
Maryland Chapter
07-25-2012 11:00 PM
TexasGuy001
28
05-01-2011 05:37 AM
stillh2o
1997-2006 Expedition & Navigator
08-13-2006 06:12 AM
BOJOFASO
Nite, Nascar & Other Limited Edition Ford Trucks
07-18-2003 08:56 PM
Quick Reply: '91 Ford D-150 Nite Brake Problems
