stumbling when cold
Old Sep 29, 2005 | 10:11 PM
Nans4X4's Avatar
Nans4X4
stumbling when cold
I have a 86 ranger 4x4 2.9L auto. Before it gets fully hot it acts like it's flooding and loses power. I have replaced many of parts -spark plugs, wires, ignition coil, PVC Valve, Idle air control, gas filter, egr valve, air filter and it stills acts the same way. Does anyone have an idea I should try. HELP!
Old Sep 30, 2005 | 05:29 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
…Enjoy FTE and The State Chapters are located at the bottom of the main forum page.
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Sep 30, 2005 | 07:40 AM
tomw's Avatar
tomw
Did you pull the malfunction codes? The problem sounds like a sensor is not telling the ECM that the engine is cold. When the engine temp is cold, or the incoming air is cold, the ECM will add a little extra fuel to help combustion. The sensors that come to mind are the ECT (engine coolant temp) and ACT (air charge temp). Fuel pressure could be a little low, thus squirting a little less fuel than the ECM desires. Check the pressure. You could also have a buildup of deposits on the inside of the intake manifold, or the area near the throttle plate (throttle body). If so, clean them out, using an "oxygen sensor safe" cleaner.
My old 2.3 will do the same thing if I don't clean out the intake regularly. It has the IAC several feet away from the intake, so it doesn't seem to get dirty, just the inside of the intake.
tom
