General Automotive Discussion
Speedometer Problem
Old Sep 29, 2005 | 09:51 AM
MemOrex's Avatar
MemOrex
Speedometer Problem
We have a problem with one of our trucks. It's a 1984 Chevy Blazer. The Speedometer will only go up to 35, but of course the truck will go faster. I know the transmission is new...so maybe it has something to do with it? I'm guessing since its old, it has a speedo. cable? Can this cause this problem? I know its a chev, but does anyone have any idea what it could be?
Old Sep 29, 2005 | 10:09 PM
AlfredB1979's Avatar
AlfredB1979
Speedo cable problems don't discriminate between brands....
Could be the cable, the gear--chipped maybe, maybe a stuck speedometer unit.....
Old Sep 29, 2005 | 11:24 PM
preppypyro's Avatar
preppypyro
yeah Im thinking possibly the cable, could also be that gear inside where the cable goes.
Old Oct 3, 2005 | 12:23 AM
MemOrex's Avatar
MemOrex
Sorry for the way late udate:
More info on it. The speedo doesnt mark anything right at all. Say im going 10mph...it'll mark around 5mph. Also, when it hits the 30mph and gets stuck, it starts bouncing up and down. Very odd.
Old Oct 3, 2005 | 09:02 AM
go_racing84's Avatar
go_racing84
Does it have cruise control? If so, does your cruise control work? I ask that because on trucks with cruise, GM used a big cruise control driver with 2 cables. One from the tcase up to the cruise driver, and once from there to the speedometer. Point is, you might be lucky and it might only be the short cable from the cruise module to the dash.
Just a thought.
Old Oct 3, 2005 | 11:08 AM
Tom's Avatar
Tom
If the needle is moving at all, that means the cable is intact. I'd say check the guage itself...maybe something mechanically wrong with it.
Being a chevy and all....
Old Oct 3, 2005 | 03:49 PM
rebocardo's Avatar
rebocardo
When I worked at a Chevy dealer in the 80s we had an account with the "local" speedometer shop to fix the Chevy heads because you use to fix them instead of returning them under warranty. Not unusual to drop off 2-4 a week. I would not be surprised if the head was bad.
