Sponsored by: Auxito
Sensor help
Old Sep 18, 2005 | 10:20 AM
plisandr's Avatar
plisandr
Sensor help
Is it possible to have codes P1151 and P1152 at the same time ? I've read that you should check for vacum leaks before repalceing sensors...true ?
Old Sep 18, 2005 | 03:28 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Sep 18, 2005 | 11:23 PM
Racerguy's Avatar
Racerguy
Welcome to the forum
A P1151 indicates a lean mixture and the P1152 indicates rich. Normally if you have just one of the codes you would suspect a vacuum leak, fuel pressure problem etc.
Since you have both codes it's probably fairly safe to assume the sensor is bad.
Of course we all know what happens when we assume though
Old Sep 19, 2005 | 07:25 AM
projectSHO89's Avatar
projectSHO89
Contradictory O2 codes almost always indicate the senmsor is shot.
Replace it.
Steve
Old Sep 19, 2005 | 09:29 AM
lancekilgore's Avatar
lancekilgore
I agree with Steve replace the O2 sensors.
Lance
