engine trouble
Old Sep 16, 2005 | 08:48 AM
86302's Avatar
86302
engine trouble
My 86 f150 with the 302 shuts off at different times when you are driving it. once you stop, it starts right up. could this be a sensor of some sort?
Old Sep 16, 2005 | 10:08 AM
Kemicalburns's Avatar
Kemicalburns
it could be your TFI module thats mounted on the distributor. I would start there
Old Sep 19, 2005 | 04:53 PM
lmadore's Avatar
lmadore
I've got a similar problem right now. Changed the TFI module and it didn't solve anything.
86 5.0EFI - F-150
I'll be driving down the road with no problem. All of a sudden, the tach drops to 0 like it loses it's signal. When I go to restart, I have to cycle the ignition key several times between the off and run position. Usually on the third cycle, it will start and run as if nothing is wrong.
The weird thing is, it only happens in the morning after it has set all night. Won't do it the rest of the day. It seems to happen during the first warm-up cycle as the truck approaches 170 degrees. After that everything is fine.
Doesn't seem to matter which tank I've got selected
Appears to be getting fuel, it restarts and runs fine until the next morning. There has been no other sign that the fuel pressure is running below normal.
When this happens, the rest of the electrical system seems to functioning.
Also, there are no codes other than the EGR, which it has had for 3 yrs now.
Mechanic is puzzled. I'm frustrated.
I'm thinking maybe EEC relay and or fuel pump relay.
Coil and Ignition pick-up test o.k., but that may change due to vibration or heat.
Any ideas.
I'm tired of chasing ghosts like this.
FUJINAMI1293
6.7L Power Stroke Diesel
18
Jan 4, 2013 01:18 PM
JumpinJoe
Nov 17, 2009 08:26 PM
5 Star Tuning
South Carolina Chapter
13
Nov 12, 2008 10:44 AM
hitecdan
Oil & Lubrication
Aug 27, 2002 11:20 AM
AlM
1978 - 1996 Big Bronco
Apr 13, 2001 11:15 PM
