I'm not expert by any means, but I'd say a good 15 - 20 mph anywhere over 35 to 40 mph. Anything below 35 I'd guess decrease amount by about 5 to 10 mph until you hit 0 mph. Does that make sense? Like I said...not an expert, but it should be fairly close.
I had stock 16" tires and 4.10's, and at 80 mph on my gauge, I was actually doing 70.
it all depends on your current setup. a 285/55r20 is a big tire, if you plan on lowering your truck then that is way too big.
285*.55*2/25.4 = 32.3"
My stock 235/70r16 comes out to 28.9"
My current 274/45r20 comes out to 29.7"
much closer.
It all depends on your stock tire size. If you have stock 235/70r 16, and go to a 285/55r20 with 4.10's, you probably wont even notice a difference in MPG/odo (sorry joe, but most ppl with 33"s re-gear to 4.10)
So you'd be pretty close to the stock EFFECTIVE gear ratio, but forget about lowering the truck with that setup. I don't even know if it'll fit under the front wheel wells unless it's a 4x4. That's the tire size most people with Expeditions use when they throw on 20's.
sorry i was off ive got 285 50 20 tires. i found out im off by 7.8% on my spedo with my wheels. does putting on new gears mess up your spedo to?
much closer.
b/c you are increasing the overall diameter, it's the same effect as putting taller gears. So to offset that, you actually DO put on shorter gears, to try to balance it out.
if at 3000 rpm you are going 10mph
on 33's you would go 12mph
throw 4.10's and you are back at 10mph
