My 302 is "gasping" for air...or something
Old 09-11-2005, 04:59 PM
El Bronco's Avatar
El Bronco
El Bronco is offline
Unhappy My 302 is "gasping" for air...or something
Well, I have a 1992 Bronco with a 302, it has no modifications. It'll run good for like 7 miles, then its starts trying to stall while im driving, and if I stop, it'll sometimes stall. I just relpaced the fuel filter, and the distributor id fairly new. Its like its gasping for air or not getting gas. PLEASE HELP! MY TRUCK HAS ASTHMA!
Old 09-11-2005, 05:37 PM
IB Tim's Avatar
IB Tim
IB Tim is offline
Site Administrator
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old 09-21-2005, 07:30 PM
bigblue86's Avatar
bigblue86
bigblue86 is offline
i have a friend that is experiencing what appears to be the same problem... has a mechanic looking at it now... mechanic thinks it might be the EGR valve, any thoughts if this might be the culprit to this annoying situation?
Old 09-21-2005, 08:19 PM
hatch_1989's Avatar
hatch_1989
hatch_1989 is offline
Simillar
It sounds simlar to the problem I am fighting with:
https://www.ford-trucks.com/forums/s...d.php?t=413026
I can just drive further.
Old 09-22-2005, 04:36 AM
Dannym's Avatar
Dannym
Dannym is offline
Yeah look at some of the stuff I mentioned to hatch. Bad vac leaks can kill the engine, especially at idle, primarily because it can't move the EGR valve. Often showes an "EGR valve position sensor error".
Fuel system, maybe.
Old 09-22-2005, 09:25 AM
Kemicalburns's Avatar
Kemicalburns
Kemicalburns is offline
pull codes. this should be uno number one on your list to do. any parts store can do it for free or do it yourself.
once youve done this let us know what you find before throwing parts at an unknown issue
Timwolve
08-04-2014 12:59 PM
tatonka82
07-31-2014 05:40 AM
nodesy
02-23-2014 10:54 PM
RoyMyr
1999 to 2016 Super Duty
07-19-2011 11:18 AM
bronco rick
1978 - 1996 Big Bronco
21
08-14-2004 10:55 PM
Quick Reply: My 302 is "gasping" for air...or something
