Gearbox ID
Old 09-23-2005, 01:36 PM
Steve_B's Avatar
Steve_B
Steve_B is offline
Gearbox ID
Hi
Can anyone identify this Gearbox or should I say transmission
https://www.ford-trucks.com/user_gal...&albumid=10233
It came with my South African 1954 F100 and sat behind a 8BA flattie
Cast in the side is:
T87D-1H
WC DIV
Stephen
Old 09-23-2005, 07:19 PM
mtflat's Avatar
mtflat
mtflat is offline
Hi Steve, the T87D is the HD 3 spd. Synchronized in gears 2 and 3. Spur gears in 1 and R. Not a bad trans for daily driving behind a flathead. That's what I'm using in my daily 48.
It rugged - bulletproof, even. I've been trying to wear this one out so I can go with on OD but it still looks like new inside after 4 years of daily use. (I just had the top off the other day) Parts are available from a variety of suppliers including Sacramento Vintage Ford.
Was your's in an industrial application? Mine has a driveshaft yoke that is attached to the output shaft.
45ford's Avatar
45ford
45ford is offline
Stephen:
It's the "heavy duty" three speed, available since at least 1948.
Mike
Old 09-24-2005, 12:17 PM
Steve_B's Avatar
Steve_B
Steve_B is offline
Thanks 45ford & Mtflat
This was in my 1954 F100, the propshaft bolts up to a square flange
Stephen
Stephen e
1999 to 2016 Super Duty
02-11-2015 05:04 AM
Stephen67
06-12-2014 02:54 PM
Quick Reply: Gearbox ID
