rebuilding a water pump
Old 10-21-2005, 02:56 PM
cbfomoco's Avatar
cbfomoco
cbfomoco is offline
out of coursity has any one done this? I would like to hear the results. thanks
Old 10-21-2005, 10:04 PM
abe's Avatar
abe
abe is online now
One Meadow Green Owner
Received 2,616 Likes on 1,456 Posts
The water pump went out on my '54 several years ago. Went to the garage to buy a rebuilt one. The parts guy said that '54's did not have a 239 engine cause his book did not show it. I told him I have one and it is original and he and his book did not know what they were saying.
Turns out the '54 water pump is different from the '55 and '56, so since it is a loner year they do not rebuild them. So my water pump had to go to a rebuild/reman shop and my truck had to sit there until it came back! So I didn't do it myself but it works good now. If you do not have a '54 you can probably find rebuilt ones. You can also find them on ebay.
abe
Old 10-22-2005, 11:28 AM
Kruse's Avatar
Kruse
Kruse is offline
Okay, the first thing I will say is that I have NEVER replaced or rebuilt a water pump for the Y-block motors. Now, with that being said, I used to work at a job where I maintained a fleet of 30 POS/antiquated/outdated forklift trucks.
Anyway, about every other year each forklift needed the water pump replaced. We would order kits for these and replace the internal parts of the water pump. You would just reuse the casting and replace the impeller and the bearings. About the only thing that was needed to rebuilt the water pump was the kit and an air press. That is, IF this uses the same type of setup and these forklifts used and I think it does. The only thing that you need is a lot of patience putting these together. They are pretty simple. Good luck.
