Camber Angle
Had some masive flex out on the trail, front right tire and left rear tire were on the ground and the other 2 tires were just assisting with balancing.
. Once I got over the rut I then proceeded to get the underside of my truck nearly perpendicular to the earth, rearly rolled it onto the drivers side but shimmied my way out of it. Whelp, when I got her out of 4x4 and back onto the highway I noticed that I had one heck of an alignment discrepency. Its that kind of alignment problem that would be really nice if I were driving on a racetrack with nothing but left turns.
The alignment isn't a big deal to me, I'll take it in to the shop next week. My concern is with what appears to be a serious toe in that wasn't there before. Drivers side tire is only off a little bit, not really noticable. The passenger side on the other hand, is really bad. I've only been driving on it for a week and I've probably run off 1/36th an inch of tread or more off the inside shoulder of the tire.
I'm worried that when I take it in to have the alignment done they won't be able to correct the camber, or worse yet, a bent frame or some other suspension part is discovered. I also wonder if I could correct an alignment problem on my own.
Anyone have any idea? Appreciate any input you guys have.
Mazda B3000 5speed 4x4
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
