1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Hooking up high idle w/upfitter switches
  #31
Old 09-22-2007, 12:19 PM
SteveBricks's Avatar
SteveBricks
SteveBricks is offline
Thanks to everyone who contributed info. on this mod. Just finished it on my '06. I used the BCP wire & the #4 upfitter switch. Couldn't be easier.
  #32
Old 01-10-2008, 02:28 AM
RedDragon777's Avatar
RedDragon777
RedDragon777 is offline
anyone know if this will work on an 08 or am i just gonna have to order the PTO feature, and does that even have a swtich or does it just kick in automatically when i push down the E brake while in park
  #33
Old 01-10-2008, 06:59 AM
rmosso1's Avatar
rmosso1
rmosso1 is offline
Thumbs up
RedDragon777:
I too would like to add the high idle to my 2008. I hope you post if you find how we need to procede. Thanks,
  #34
Old 01-10-2008, 10:57 AM
94yj's Avatar
94yj
94yj is offline
  #35
Old 01-10-2008, 11:25 AM
RDJ184's Avatar
RDJ184
RDJ184 is offline
ryaneverk2 with what you said and the response from the members i will be doing this this weekend i run code 3 light sys on my truck some times for long durations this sounds like the perfect mod for me thanks
  #36
Old 01-10-2008, 11:42 AM
rmosso1's Avatar
rmosso1
rmosso1 is offline
94yj:
Thanks for the link. I read thru the sixteen (16) page bulletin. Great info. I once had someone ask if I were an electrician; and my response was that I was a two wire hook up; alas, another friend said he thought I was a three wire ... up.
Thus, with the number of wires involved, maybe later in the year! Thanks, What that Special Vehicle Engineering reaffirms to me is the brain power and thought behind our Ford vehicles.
  #37
Old 06-21-2008, 07:21 PM
4starcstms's Avatar
4starcstms
4starcstms is offline
Can you do the up Idle Mod if you have a manual or am I just stuck goin the spensive route??
2004 PSD btw ..
  #38
Old 06-21-2008, 07:30 PM
carls 250's Avatar
carls 250
carls 250 is offline
Done it on my 06 250 w/5.4 only took idle up to 950 rpm.
  #39
Old 06-21-2008, 09:26 PM
NICK08SD's Avatar
NICK08SD
NICK08SD is offline
Hey Guys ,i Tried To Hook Up My 08 5.4 Idle Also .doesn't Seem To Want To Work. Anyone Try A 08 Gasser Yet? Followed Ford Directions ,still Won't Work.
  #40
Old 06-22-2008, 07:43 AM
94yj's Avatar
94yj
94yj is offline
on mine an 08 f 250 5.4 i did a while back and it works fine i put mine on up fitter SW # 4 which boosts the rpm up to 900 rpm and a pot SW which goes the rpm up to 1500 rpm nick it sounds like something did not get wired up right on your end as it took me a few trys to get it wired up right when i did mine
  #41
Old 06-22-2008, 11:01 AM
NICK08SD's Avatar
NICK08SD
NICK08SD is offline
Is It Possible For You To Check Your Wires And Tell Me Which Ones You Hooked Up? I Know Chart Gives Us A Couple Of Different Poss. Thanks.
  #42
Old 12-13-2008, 08:12 PM
madone04's Avatar
madone04
madone04 is offline
upfitting for hi idle, 03 6.0l
Is The Procedure Different For An 03 6.0l?
If So Could Someone Help Me Out With This One?:-x25
  #43
Old 12-15-2008, 01:24 PM
Lonewolftx's Avatar
Lonewolftx
Lonewolftx is offline
Wink
Note posting #18 which should also apply to your year as well.
  #44
Old 12-15-2008, 08:06 PM
madone04's Avatar
madone04
madone04 is offline
thanks .I will try this in the morning and repost
  #45
Old 01-19-2009, 01:03 AM
jksweld's Avatar
jksweld
jksweld is offline
Does anyone know if this mod will work on a 04 F-450 V10?
The truck Iam looking to buy has a electric over hydraulic crane on it and this would be really handy to have to rev the engine up when running the crane to keep the batterys up. I know this truck doesn't have the upfitter switchs, but Iam going to build a switch box for this and my work lights.
Thanks
James
Quick Reply: Hooking up high idle w/upfitter switches
