Shock brackets
Old Aug 16, 2002 | 02:57 PM
beartracks's Avatar
beartracks
Shock brackets
Do the front lower shock mounts stick up or down where they attatch to the radius arm? I've got to start taking pictures of this stuff before I take it apart.
Old Aug 16, 2002 | 03:05 PM
laptopgeek's Avatar
laptopgeek
Shock brackets
BearTracks - no need to take pictures; I already have -
http://www.beedzncomputers.com/truck/suspension/frtspnginstall/frtspnginstall.html
Hoping this helps....(these are Monroe Gas-o-matics)
Old Aug 16, 2002 | 03:46 PM
dfisher1's Avatar
dfisher1
Shock brackets
Bear,
I'll bet you could flip that bracket either way depending on the ride height of your coils. I found that many different applications for the same part can be used when modifing factory intent.
KingFisher
Old Aug 16, 2002 | 07:53 PM
beartracks's Avatar
beartracks
Shock brackets
[updated:LAST EDITED ON 16-Aug-02 AT 09:07 PM (EST)]Dang, a picture really is worth a thousand words. Thanks both of you. That might soften up my ride if I turn em back over.
I guess with a stock, a longer or a shorter shock and turning the bracket you could really get you shock centered after altering things.
Hope to post some pics of my ride soon.
Old Aug 16, 2002 | 07:54 PM
beartracks's Avatar
beartracks
Shock brackets
