352 idling problem
Old Aug 30, 2005 | 07:25 AM
mark alderson's Avatar
mark alderson
352 idling problem
My Truck Will Not Idle At Times.sometimes It Runs And Will Idle Just Fine.then It Will Take Anotion Not To.i Have Adjusted Idle Screw .the Truck Runs Fine Otherwise.any Suggestions?
Old Aug 30, 2005 | 11:47 AM
Bear 45/70's Avatar
Bear 45/70
Have you changed the PCV valve? They can do some strange stuff. Have you changed the fuel filters? When it won't idle, does it run ok at other than idle?
Old Aug 31, 2005 | 09:59 AM
mark alderson
the truck runs fine even when not idling.but occasionally it will not idle
Old Aug 31, 2005 | 05:11 PM
1975Ford's Avatar
1975Ford
Maybe some bad gasoline??? Maybe a random vacuum leak??? Maybe a dirty carburator???
Old Aug 31, 2005 | 05:17 PM
ford390gashog's Avatar
ford390gashog
try the mixture screws
Old Aug 31, 2005 | 05:56 PM
Bear 45/70's Avatar
Bear 45/70
I would suspect dirt in the carb at this point too. Check the air cleaner also, dirty filters do strange thinks.
Old Sep 2, 2005 | 09:17 AM
mark alderson
I Changed The Pcv Valve And Rubber Grommet.it Was Running And Idling Fine Yesterday.maybe This Has Solved The Problem.thanks For The Tips.
godtar02
Dec 29, 2014 03:42 PM
cajunsuperduty
Oct 28, 2011 03:31 PM
dan b
Apr 3, 2010 08:01 PM
kmstokes
Jan 12, 2003 03:59 AM
danm
Feb 14, 2000 09:08 PM
