Hi
I Have A 2001 F250 7.3 Been A Great Truck .to Day On My Way Home From
Work It Started Running Rough.
I Took Out My Super Chip Programer And Checked The Codes And It Came Up With P1316.my Question Is Where Do I Begin Looking For The Cause Of This Code Or Do I Send It To The Dealer To Have It Fixed.
Any Info Would Be Apreciated.
The code is a fault in the IDM. This if not fixed can cause an injection timing problem and engine damage. If you don't have the diagnostic ability take it to someone that can.
DIAGNOSTIC TROUBLE CODE (DTC) P1316 INDICATES THAT CODES ARE STORED IN THE IDM
Possible causes:
Injector(s) or circuit(s)
Open or shorted IDM enable circuit
Open/short in EF circuit
Open/short in FDCS circuit
IDM relay
IDM powering circuits
IDM
PCM
