NEED 302/ 332 HD Y-Block Crank or INFO
Old 04-26-2010, 08:36 PM
eratchetos's Avatar
eratchetos
eratchetos is offline
If tom dosn't want the 332 crank, I am interested please give me a call 316 778 1877 or 316 778 1122 Eratchetos
  #32
Old 04-27-2010, 09:42 PM
eratchetos's Avatar
eratchetos
Ok call me on 332 crank I need one 1 316 778 1877
  #33
Old 04-28-2010, 06:33 AM
old uhaul's Avatar
old uhaul
old uhaul is offline
I tried to call you a few times, even on days, and the number was always busy.I still have the complete stock 1956 F900 332 from the firetruck.631-433-0048 Tony
  #34
Old 04-30-2010, 06:43 PM
eratchetos's Avatar
eratchetos
Do you still have 332 truck crank?
  #35
Old 04-30-2010, 06:46 PM
eratchetos's Avatar
eratchetos
Welcome to FTE
C3TZ6303A replaced B8Q6303A fits 1958/63 302/332.
But...no Ford Dealer or obsolete part vendor has either one.
Try: Southern California Truck Wrecking (in business, same family owned since 1929) / 323-587-3144, ask for Marty / Open M-F closed weekends.
btw: When buying Ram's Horn exhaust manifolds, be aware there are three different types...they do NOT interchange!
Lincoln Y blocks / Ford Y Blocks / 1964/78 FT engines.
Bill will a 1956 332 out of f900 truck fit my 1956 Lincoln 368 engine?
  #36
Old 04-30-2010, 06:47 PM
eratchetos's Avatar
eratchetos
I forgot to say the crankshaft!
  #37
Old 05-02-2010, 09:01 PM
eratchetos's Avatar
eratchetos
I want to buy crank will be at 719 748 1400 on Tuesday call if you want to sell
  #38
Old 03-16-2014, 06:23 PM
312's Avatar
312
312 is offline
anyone know what happened to tom and his project.
  #39
Old 04-26-2014, 07:23 PM
richardge's Avatar
richardge
richardge is offline
I'm looking for an intake manifold from a '57 - '63 302, 332 cu in engine that used the Holley 4150 carb. Anyone that wants to sell one or know where on might be at let me know, please.
Thanks, Richard
  #40
Old 08-25-2014, 11:20 PM
Elgin Boy's Avatar
Elgin Boy
Elgin Boy is offline
Hello,
I am Elgin Boy. I am looking for a 302/332 HD Y Block steel crank for my 368. I also understand the intake off the 302 / 332 has a higher profile, unlike the 4 barrel manifold on my 368 which resembles a squished spider. (NO Performance). I would be interested in buying a 4 barrel manifold if what I am saying is true about the higher profile for the carb mounting than on the stock 368. Any help out there would be appreciated. Thank you.
  #41
Old 08-26-2014, 06:48 AM
richardge's Avatar
richardge
I've been looking for one of these manifolds for months and haven't found one. Be sure and get the heads too if you find an engine. The heads are steel reinforced and have special valves. The crank is forged steel so get all three.
I got a 4GC Rochester carb from a '65 Chevy 327 and used a TransDapt adapter which fits my '53 Lincoln OK without any clearance issues so I don't have to use a carb riser. The problem was I didn't have the original carb (Junk Holley) with my car. I couldn't find a Carter WCFB from a '56 or '57 Lincoln either. Right now I'm not interested in getting more performance out of my engine so everything should work OK.
Good Luck
  #42
Old 08-26-2014, 01:41 PM
Elgin Boy's Avatar
Elgin Boy
Richarge,
Thank you for your input. I am not sure about the 332 heads but the heads I have on my 368 were better than the previous Y block heads for different reasons ...valve size better rocker assy, etc. Maybe best is to try to get a 332 engine out of a F7or F8. I am not sure but they may have had a solid lifter cam that could be reground for more duration. Like you said this stuff is nowhere to be found.
Elgin Boy
  #43
Old 08-26-2014, 01:48 PM
Elgin Boy's Avatar
Elgin Boy
Do you still have the 332 motor or is it gone?
Thank you
Elgin Boy
  #44
Old 08-26-2014, 03:17 PM
richardge's Avatar
richardge
Cam duration and rocker arm lift were designed much different than the Lincoln passenger cars. Also I think the cams may have rotated in the opposite direction than the car engines. Heads, manifold and crank would fit the car engines OK.
There probably was some hi perf stuff around for the Mercury Marauder. Some had 2 4's from the factory. Last time I saw one for sale it was $3,000 on e-bay. Seems like there were some 3 2bbl setups available too back in the day but I haven't seen one anytime lately. Trying to do anything with these cars is expensive. Only reason I'm doing it is there's probably not more than 50 cars left like the one I have.
  #45
Old 08-27-2014, 11:15 PM
Elgin Boy's Avatar
Elgin Boy
I Need a 332 Lincoln truck crank.
Quick Reply: NEED 302/ 332 HD Y-Block Crank or INFO
