Fuel problems?
Old Aug 1, 2005 | 10:46 AM
bknight's Avatar
bknight
Fuel problems?
Hey everyone. I have a 94 explorer XLT that quit on me yesterday. I had stopped at a intersection and suddenly the idle became very chuggish, everything was normal up until then. There was very little response from the throttle at this point, just enough to get me through the intersection and then there was no response at all. The engine was still idling very rough and then eventually stalled after about 2 minutes. When trying to restart the engine, it would actually start no problem ( first turn of the key each time), but would run very rough again and stall within 30sec-1min. I let it sit for about 30 minutes, tried it again and it started and ran fine to get me home. Any thoughts would be very helpful. Thanks in advance. Brian.
Old Aug 1, 2005 | 01:08 PM
mrshorty's Avatar
mrshorty
I would start by pulling codes from the computer.
Old Aug 2, 2005 | 05:29 AM
marragtop's Avatar
marragtop
Pulling codes is definitely where to start. If they don't reveal anything, consider the fuel filter if it hasn't been replaced.
Old Aug 2, 2005 | 05:54 PM
bknight's Avatar
bknight
I checked for codes and there wasn't any. The only other time it did this was last summer when it was 34c outside (roughly same temp. this time too). It seems as soon as the temperature cools down the problem goes away.
Old Aug 3, 2005 | 01:05 AM
mrshorty's Avatar
mrshorty
Does this mean, "no codes at all, the computer didn't respond during the test." or, "all pass (111) codes."
Old Aug 27, 2005 | 01:10 AM
FunkyDoGooder's Avatar
FunkyDoGooder
It sounds like the IAC Sensor may be your problem. We've discussed it in another post. Others have reported similar behavior. =)
Good Luck,
Funky
Old Aug 27, 2005 | 07:51 AM
JerrySimm's Avatar
JerrySimm
IAC typically doesn't cause a lack of throttle response. One of the ways to know that's the issue is that it will run if you give it some throttle. Back to MrShorty's question, did it give no codes or no codes other than all clear? If it gave the all clear, you should check the fuel pressure. Could be a filter, as Marragtop has already said, or it could be the fuel pump. Also, check your vacuum tree and hoses to make sure you don't have a large vacuum leak. The tree is on the intake at the rear of the engine on the drivers side.
320kmiles
Jan 19, 2014 09:35 PM
jamesonblade
Aerostar
Nov 15, 2012 12:10 AM
Vyndrah
1983 - 2012 Ranger & B-Series
Oct 28, 2012 01:34 PM
troybuilt1
General Diesel Discussion
Sep 12, 2010 10:08 AM
surveyguy
76
Apr 18, 2009 10:19 PM
