Speedometer Adjustment
Old Jul 26, 2005 | 01:53 PM
stevew15's Avatar
stevew15
My in dash speedometer is reading about 10mph slow at 40 mph actual. If I'm going 40, it read sabout 30. The truck does not have the original tires on it. That is probably this problem. Question is: is there any way to calibrate or adjust this?
Old Jul 26, 2005 | 02:14 PM
PROSTOCK's Avatar
PROSTOCK
That's too far off to be just tires. I would suspect that the rear end gear ratio has changed at some point. A ratio change will make your speedo be off by the same ratio. If your speedo reads 15 when you are going 20 and, if you dare, reads 60 at 80, then that's most likely a gear change. The easiest way to correct this would be to change the speedo gear at the tranny according to the rear end ratio.
Old Jul 26, 2005 | 03:44 PM
stevew15's Avatar
stevew15
Your right, the gears have been changed as well. My dad did it when he owned the vehicle. How do I know which speedo gear to get? Who would carry such an animal?
Old Jul 26, 2005 | 05:47 PM
barry's Avatar
barry
Your local Ford dealer can get the gear you need. If it's only 10 MPH, then you need to get a gear with one less tooth than what's on the end of the cable now. Pull the end of the cable out of the tranny and take the gear off the cable. Take the gear to the parts dept and tell them you want a gear identical to this one, but one less tooth. That will make the speedo read closer, if not correct now. I have the parts books to look them up if you want me to. Send a private message and I'll help you out.Don't let the dealer say they're obsolete, because they're not. I do this all the time.
Barry
Old Jul 26, 2005 | 08:26 PM
RaleighDad66's Avatar
RaleighDad66
Tell us how many teeth are on the end of the speedo cable and we may have one with the correct tooth count. After all, one less tooth is kinda common here in NC!
Old Jul 27, 2005 | 08:55 AM
stevew15's Avatar
stevew15
Thanks guys. I'll pull it this weekend and send a private message about the tooth count and any other details.
