Lighting Issues
Old Jul 16, 2005 | 09:06 AM
kij2004's Avatar
kij2004
Lighting Issues
I recently attempted to put some extra lights on my 87 F-150 that I have had for some time. Unfortunately I have the same problem that I had years ago and that is why I stopped using them. I can not seem to stop the wiring from frying. The last one that I used was 12ga and it lasted a little while then smoked itself. Nasty smell by the way. I am also going through switches. I have tried using a relay without much luck, might not be the right size. Any help would be apreciated since I really like the amound of light that these give off. Just to help they are 300 watt 55 amp lights and I have 4 of them.
Old Jul 17, 2005 | 01:16 AM
MemOrex's Avatar
MemOrex
So that's 1200 watts of pure lighting? The alternator will fry, unless you have a huge one.
12ga is too small....use 8ga. You will need huge relays, I've never seen bigger than 30AMP (12v). If you run it straight thru a switch, it will melt.
Old Jul 17, 2005 | 07:39 AM
EPNCSU2006's Avatar
EPNCSU2006
Bosch makes a 75 amp relay, that might be a possibility for you to try. That's a lot of wattage, and I agree that it'll strain the alternator. How do you have them wired presently? Are they wired individually, or are you powering all four with one 12 ga. wire? Also be sure the wiring is fused and that the ground wire is equally as large as the power wire and has a solid connection to ground.
75A relay: http://order.waytekwire.com/IMAGES/M...og/217_053.pdf
The rest of the catalog: http://www.waytekwire.com/CatPDF.htm
Waytek is a good company to deal with for wiring needs, as well as delcity.net
Old Jul 19, 2005 | 11:06 AM
kij2004's Avatar
kij2004
Thanks for the info. I have burned up a few switches in my time. I usually do not have a problem with the alternator since the wiring gives out long before that. Anyone ever tried to run dual alternators with a switched clutch to engage the second one? Anyway i will try the places suggested. I might be able to find out what plane these came out of an see what they are using for wiring and relays. Yes...before you ask they are aircraft landing lights. If you're gonna go...go BIG!
BCHauler
Feb 9, 2011 03:28 PM
Douglas DC-9
Feb 7, 2009 09:28 PM
Jag Red 54
29
Jun 14, 2005 05:13 PM
