Help quick please
Old Jul 7, 2005 | 09:54 PM
fordbubba8206's Avatar
fordbubba8206
i have a question, that actually refers to fords
, my truck wont start, its making me mad, its something in the electrical
Old Jul 7, 2005 | 09:55 PM
Mil1ion's Avatar
Mil1ion
Maybe Try the truck forum that matches your truck
Old Jul 7, 2005 | 10:04 PM
924x2150's Avatar
924x2150
Bubba, if you want help, just ask. However, You aren't going to get it here.
Go to the correct forum, tell us everything about your truck, that is, what engine, trans, year, model , etc. and ask a question.
Old Jul 7, 2005 | 10:27 PM
fordbubba8206
it wont let me start a new thread
Old Jul 8, 2005 | 11:43 AM
fordbubba8206
ive put on a new solonoid, starter, key switch, battery, battery ends, plugs and wires. ive opened up the carb, and im getting fuel. i dont know if my harness is fried, or what it is, ive driven it, and it jsust died, it cranks, so i have no idea. please help. its a 1983 F-150 4x4, man trans, 5.8L windsor. reg cab, long bed.
Old Jul 9, 2005 | 02:31 PM
WhëëlMå1's Avatar
WhëëlMå1
Moved to electrical forum
Old Jul 9, 2005 | 03:23 PM
John Rowe's Avatar
John Rowe
Is there spark to the spark plug? If not, maybe the coil, rotor, distributor cap or distributor. Check inside the distributor cap see if the contacts are fried on the cap or rotor.
It could also be the ignition module, the box on the driver's side fender with two plugs coming out of it. Make sure you get the right color module (they will ask what color the grommet coming out of the box is).
Old Jul 9, 2005 | 09:20 PM
Franklin2's Avatar
Franklin2
Yes. take a screwdriver and stick it up in one of the sparkplug wires after you pull the wire off one of the sparkplugs. Hold the screwdriver by the plastic handle, and hold the metal shank very close to a metal part of the engine. Get someone to crank the engine over, and you should see a strong blue spark jump from the screwdriver to the metal.
If you don't have spark, the first thing I would do is pull the distributor cap off and then get someone to crank the engine just to make sure the rotor spins around. If it does, then follow the previous poster's advice and change the module on the fender.
Fomoko1
Sep 19, 2016 09:04 AM
IHCubCadet
General Automotive Discussion
Jul 23, 2016 01:42 PM
dj lpm
2015 + Expedition & Navigator
Apr 15, 2016 12:31 AM
wawii
Jan 5, 2016 10:26 AM
priley
Exhaust Systems
Feb 6, 2001 12:49 PM
