Sponsored by: Auxito
Inconsistent starting problems
Old Jun 28, 2005 | 04:38 PM
clcass55's Avatar
clcass55
Question Inconsistent starting problems
I have a 2000 F150 4x4 with a 5.4L engine. I am experiancing a problem starting the vehicle that doesn't happen all the time. Sometimes I turn the ignition and the truck doesn't even try to start and the power to the dash goes off including the radio. Then when I turn the key back to the accessories position the radio doesn't turn back on, but the instrument panel seems to be working fine. This happened a couple of days ago and I had the vehicle towed to my house and now it is starting again. Any ideas?
Old Jun 28, 2005 | 05:59 PM
dbarn's Avatar
dbarn
Inconsistent Starting Problems
I have a 2000 Expedition 4x4 with a 5.4L engine as well. Just today the same thing happened to me. I put the key in the ignition and nothing happened. I tried several more times and nothing. I called AAA and they came out and tried to jump the truck. Nothing. The AAA guy said he thinks it is the Anti-Theft System because he has seen this in newer Expeditions and F-150s. He leaves to get a flat-bed to tow my truck. I try one more time, then it starts. I then call a guy at a local auto-repair and he explains to me that the same thing has been happening to a guy at the shop. What he knows is that it has to do with the Vehicle Anti-theft System or VAT System. It is within the Electric Control Module or ECM. This person had to take it to Ford, who had his truck for a couple of weeks before they figured it out. This a very common problem in Ford Trucks. This guy said that the fix should be covered as a recall because it is a safety issue or at the very least it is covered under warranty. I am suppose to talk with the guy who had the problem later today. I will post what I find out and how he dealt with the problem. Have you found out anything about this?
Old Jun 28, 2005 | 07:12 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome WOW...two on one thread...clcass55 and dbarn, to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jun 29, 2005 | 08:00 AM
mizzleman's Avatar
mizzleman
I just recently had similiar starting problems. The truck would start when cold, but wouldn't when warm. It turned out to be the starter relay.
doczenith1
6.7L Power Stroke Diesel
20
Oct 27, 2016 03:44 PM
drewcruise
Aug 31, 2015 12:07 PM
MAD
Aug 2, 2014 01:27 PM
DieselMechanic
1983 - 2012 Ranger & B-Series
Jan 10, 2014 09:43 PM
