Check engine light with codes
Old Jun 26, 2005 | 07:31 PM
Raptor1's Avatar
Raptor1
Hi all, this is my first post so bear with me. I've got a 97 F-250 with the 460. Last week, my check engine light came on and I scanned the codes with a reader from Autozone. The codes that came out were a "171" and a "174" which indicated a lean condition. Has anyone seen this before and what is the solution? I had the O2 sensors replaced 10,000 miles ago if that helps. Thanks
Dave
Old Jun 28, 2005 | 09:51 PM
Raptor1's Avatar
Raptor1
Anyone? Thanks
Old Jun 29, 2005 | 12:26 AM
griffith04's Avatar
griffith04
Lean is either a vacuum leak(check each one through the plastic loom) or injectors or fuel delivery problem i.e. low fuel preasure
Old Jun 29, 2005 | 08:11 AM
goofy173's Avatar
goofy173
I was led to this thread when I reported the same thing pretty much.
https://www.ford-trucks.com/forums/s...ead.php?t=8933
Old Jun 29, 2005 | 06:40 PM
Raptor1's Avatar
Raptor1
Great info, thanks. Sounds like I'll be checking my PVC valve/hose.
