I think I narrowed down my "won't go into gear sometimes" problem down to needing to bleed slave cylinder or maybe replace it--my problem is how to bleed the clutch? I dont see anything on the slave cylinder to allow this--any help?
Look right above where the line enters the slave and you will find an allen head screw,that's the bleeder.There may be one on the clutch master also.
Phillip
