Free Mobil Oil!
Old 05-25-2005, 01:16 PM
debeer's Avatar
debeer
debeer is offline
Free Mobil Oil!
Mobil is giving away 5 free quarts of Mobil 5000 oil to the first 5,000 who sign up. The giveaway begins on Thursday, May 26th at 12:01am CST, void on June 1st at 11:59pm or when 5,000 registrations have been received. Check sent to you has no cash value and can only be used for the purchase of Mobil Clean 5000 quarts at participating retailers (all majors are participating).
Go to this site as close to 12:01am CST on May 26 and follow the instructions. It works! I received my "check" for 5 qts(last weeks giveaway)from Mobil in one weeks time.
http://www.5quartsfree.com/5QuartsFree/
BTW if you "click here" now, you will only get a rebate form for 1 free qt with 5 qt purchase. Wait until 12:01am CST on May 26 for the 5 FREE qts!.
Specs on oil
http://www.mobiloil.com/USA-English/...lean_5000.aspx
Old 05-25-2005, 01:28 PM
Ruckus's Avatar
Ruckus
Ruckus is offline
Gee, I will have to miss some of Jay Leno!HaHa Thank You!
Old 05-26-2005, 12:19 AM
Ulf's Avatar
Ulf
Ulf is offline
debeer,
Thanks for the information on free Mobil 5000 oil, I just signed up for it and got accepted.
Thanks!
Old 05-26-2005, 01:14 AM
Forrest_F150's Avatar
Forrest_F150
Forrest_F150 is offline
ulf,
i signed up... not sure if i won though...
did your message say something like, check your email in the next 7-10 days for your free mobil 5000 coupon check?.......
Old 05-26-2005, 01:15 AM
Monsta's Avatar
Monsta
Monsta is offline
Sit. Stay.
Boo-Hoo...Not available in Hawaii...
Old 05-26-2005, 01:18 AM
debeer's Avatar
debeer
debeer is offline
Yes, you made it in time. Check will be sent in the mail. Glad I could be of some help. ENJOY!
BTW they are very punctual with the checks.
Old 05-26-2005, 01:20 AM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
yep this has been posted on the BITOG for some time and it goes quick i posted this in the oil forum i got mine
Old 05-26-2005, 01:25 AM
Lead_Foot's Avatar
Lead_Foot
Lead_Foot is offline
yea, and u got a confirmation code, im pretty sure it means we get the free oil, hmm i have to check my manual, this will be my first oil change on my own vehicle, im not sure how much my 460 holds hehe, btw thanx debeer.
Old 05-26-2005, 07:21 AM
Ruckus's Avatar
Ruckus
Ruckus is offline
Smile
I forgot about it last night.I tried this morning and was too late.Boo Hoo!You snooze you lose .Maybe next time.Thanks!
Old 05-26-2005, 11:53 AM
Ulf's Avatar
Ulf
Ulf is offline
Originally Posted by Forrest_F150
ulf,
Yes, that is correct I also got a confirmation #
Old 05-26-2005, 03:09 PM
ford390gashog
I hope you don't paln on using that mobil 5000 in the 460 doesn't hte 460 have a flat tappet cam i think it does if so this oil and all sm rated oils are not made for flat tappet cam engines the new sm rated oils cut the zinc in half to meet emissions you could shear a cam lobe by not running enough zinc take a look in the oil forum or ask rusty or flash.
Old 05-26-2005, 08:40 PM
Forrest_F150
is it OK to use the oil in our 5.4 liter V-8's?..... i have 1,500 miles and was thinking about changing my own oil and filter at 2,500... i plan on replacing the oil plug with one of those drains with a open/close lever on it that i have seen on a few websites..... but i am not sure if i should use the free 5qt's of MObil 5000 that i will be getting (plus an additional 2 qts as the 5.4 l takes 7) or if i should just put Morocraft factorty oil in the truck instead and give the Mobil 5000 to a friend....???
Old 05-26-2005, 08:47 PM
Lead_Foot's Avatar
Lead_Foot
guess its goin in my moms trucka little 3.4l toyata v6, o well, she'll buy the oil for my rig's oil change couldnt be a fair trade lol.
Old 05-27-2005, 01:21 AM
ford390gashog
The mobil oil is a perfect oil for the modular engines ford reccomends using 5w20 in the modular engines now but they used to reccomend 5w30 both oils are very good for this engine the 5w20 gets the cafe numbers up in tests both oils perform well in these eninges because they are very gentle on the oil anything over 5w30 in these engines is pointless you can actually ruin them you can drain the sump and burn up the lower bearings or have no oil on startup there is people that think they need a heavy oil like 15w50 in these enignes because they tow a trailer that is simply not true the tests have shown they wear out faster with thick oil and ford tested these modular engines to the extreme on the 5w20 oils and they performed well very little wear.
Old 05-27-2005, 01:26 AM
dondon623's Avatar
dondon623
dondon623 is offline
Angry
I Tried but I missed out, {pouting}, but thanx anyhow.
Quick Reply: Free Mobil Oil!
