shuddering engine
Old Apr 5, 2000 | 12:06 AM
timmgill's Avatar
timmgill
shuddering engine
Occasionally, when I turn off my engine, the engine will shudder for about 3-4 seconds before stopping. Any idea what is the problem?
Old Apr 5, 2000 | 09:23 AM
PAUL_2's Avatar
PAUL_2
shuddering engine
Tim ,
What engine are you referring to ? Its possible the timing isnt set properly ? It may be carbon buildup ...the carbon gets hot enough to keep igniting the Air/Fuel mixture . A lower than needed octane in the gas you are using may contribute also .
Paul
Old Apr 5, 2000 | 02:03 PM
FORDTRUCKMAN1976's Avatar
FORDTRUCKMAN1976
shuddering engine
most likely your idle speed is set too high, or your timing is too advanced
Old Apr 5, 2000 | 05:16 PM
timmgill's Avatar
timmgill
shuddering engine
It is a 1981 F100 with the 300 I6.
Old Apr 5, 2000 | 07:26 PM
Nathan's Avatar
Nathan
shuddering engine
