General Automotive Discussion
Codes
Old May 11, 2005 | 10:03 PM
durk's Avatar
durk
Codes
i just put a new motor in my taurus and when it was finished I got three codes from the computer, P0118, P0122, and P1504. I replaced all the sensors that could cause these codes but I still have them. I have cleared them but they come back. The cars idle is a little funny, it idles really high when first cranked, then idles really low, like 400 rpm. It is still driveable but I want to get this fixed, so if there is a mechanic here that can give me a solution for this please let me know.
Chad
Old May 12, 2005 | 01:06 AM
pfogle's Avatar
pfogle
Check for vacuum leaks.
Old May 12, 2005 | 09:55 AM
TigerDan's Avatar
TigerDan
The codes don't always indicate a problem with the sensor, specifically. They indicate a problem with the circuit as a whole. It could be simply a bad connection or a loose wire, did you perform a 'wiggle' test, where you wiggle the wires and connectors? -TD
