Front end
Old Jun 27, 2000 | 01:11 PM
billv's Avatar
billv
Front end
I was wondering about how much a 4 wheel alinement with them changing ball joints should run
Old Jun 27, 2000 | 01:29 PM
PAUL_2's Avatar
PAUL_2
Front end
A front alignment will run between $40 to $50 . Changing the ball joint prices will vary a lot depending on whether your truck is 2 or 4 wheel drive . Plus the cost of the ball joints . Id suggest getting a quality set of both upper and lower ball joints that have grease fittings . Best thing to do is call around to a few different shops and get some prices . If your pretty handy will tools and have a 2wd its a job you can do , the 4wd drive requires a little more work and expertise , but you can do it . It will save you some money . Id recommend getting a detailed service manual if you have never done that sort of work before . If you run into any trouble one us can help you out .
Paul
Old Jun 27, 2000 | 05:05 PM
bajhafords's Avatar
bajhafords
Front end
