No codes from EEC-IV
Old Sep 12, 2000 | 12:17 PM
nar9695's Avatar
nar9695
Hi all,
I own an 86 F-150 with the 4.9 l I6 and 4-spd manual. The motor is carbureted, with EEC-IV and feedback carb.
Lately, I have been plagued with the rough idle problem that many other truck owners seem to have experienced. I have aleady checked for vacuum leaks, and have replaced the distributor, plugs, wires, and coil. Still have rough idle.
I purchased a SunPro code scanner, and hooked it up as directed. The problem is, the STO (self-test output) light is on constantly! When I start a KOEO test, I can hear sounds in the engine comp, but the STO light remains on constantly, so I receive no codes whatsoever.
Does this mean I have a bad computer?
Thanks for your help.
Old Sep 12, 2000 | 07:15 PM
keence's Avatar
keence
Make sure the tester is in the "Hold" position before you turn your key on. After the key is on then turn the tester to "Test". Are you hooking up the extra single wire to the tester? This needs to be hooked up also. Hope this helps.....
Brian & Kathy
1993 F150 Flare Side 5.0L Electric red with bright silver step and ground effects with matching hard cover - PW/PDL tilt, cruise, Captains chairs with lower lumbard, center console.
1989 Lincoln Continental Signature - Cheap to buy - expensive to work on. Signature Series 3.8L - Head gaskets.... I Know!
1989 Probe 2.2L - Fast little car!
Old Sep 13, 2000 | 06:24 AM
nar9695's Avatar
nar9695
>turn your key on.
Did it. The STO light comes on as soon as I hook up the "doghouse" connector.
>After the key is on
>to the tester?
Yep, hooked up the single wire. Still constant STO.
This leads me to believe that I have either a bad computer, or something amiss in the wiring harness.
Steve
Old Sep 13, 2000 | 11:11 PM
PAUL_2's Avatar
PAUL_2
Try using just a jumper wire on the Signal Return Pin & the Self Test Input & using the vehicle Check Engine Light to check for any codes Vs using your Sun Pro . Much easier to use . The problem may be with the scan tool instead of your trucks computer .
Old Sep 14, 2000 | 12:04 PM
nar9695's Avatar
nar9695
Thanks for the suggestion. Here's what I did, just today.
Looked carefully at my instrument panel. Saw a space where the "emissions" light should be. Pulled the panel to see if the bulb was bad. There was NO bulb! No only was there no bulb, there wasn't even a bulb socket, nor could I see a place where a socket might have been cut out of the wiring harness! Weird, huh ?
I still think I might have a bad PCM.
More troubleshooting tonight.
Steve
Old Sep 15, 2000 | 10:38 PM
sjb's Avatar
sjb
I believe that emission lite has to be in the circuit and good in order to read codes from anywhere. I replaced the bulb in my '90 E-350 with one from RadioShack. Ford couldn't even find a listing for it. It's a 12 volt miniature lamp, 60mA. They were out of the clear one so I bought a pack of three (RS#272-1099, $1.29) and used the red one.
sjb
Old Sep 15, 2000 | 11:56 PM
Neil's Avatar
Neil
Da_Lariat_Chariot
Mar 20, 2018 08:25 PM
john165
Jul 21, 2012 06:09 PM
mike L
Jan 23, 2010 10:08 AM
TrucksNamed"PHIL"
Apr 1, 2007 08:58 PM
jmcdaniel99
Bronco II
Sep 16, 2003 08:46 AM
