will not start
will not start
89,f150,5.8 turn key on, no fuel pump ticking, tried 2 new relays, just cranks, checked for fuses, all good, checked spark, all good, just cranks, checked fuel pump shut off on inside firewll,ok. will put my code tester on shortly. switched tanks,same thing, i put in a new relay 2 months ago because old one was rusty & it wouldnt start then. it worked good til yesterday. thanks for any suggestion
will not start
there are no click,click, click from anytging. even when i unhook the batt. & reconnect no clicks, it just cranks. i took off the right kick panel & there is no comp. mod. in there. where else might it be??????????? other times when i unhook batt. & reconnect i always had clicks.
If the EEC Power relay is not making a clicking sound when you turn on the key it is not the computer at this point.
You may have a bad Ignition switch, EEC power relay (Brown) or its socket or wiring under it. It could also be an open fuse link at or near the starter relay on the fender.
Also make sure you check the small ground wire coming off the NEG post of the Battery is OK.
The location of the computer to answer your question:
