5.0 or 5.8
Old 02-06-2001, 08:09 PM
billyb's Avatar
billyb
billyb is offline
5.0 or 5.8
Old 07-15-2001, 02:12 PM
shark4315's Avatar
shark4315
shark4315 is offline
5.0 or 5.8
Is the 5.0L engine better or is the 5.8L better? I'm going to buy a truck and do some minor mods to it like K&N, flows, headers, stuff like that. Which engine would be better for that?
Old 07-15-2001, 05:31 PM
Pastmaster's Avatar
Pastmaster
Pastmaster is offline
5.0 or 5.8
Both will open up good with mods, but it really depends on what you want and find. The 351 is an excellent work motor but gets alot worse mileage than a 302 would. What years are you looking for?
Old 07-16-2001, 11:23 PM
Fordtruxrok's Avatar
Fordtruxrok
Fordtruxrok is offline
5.0 or 5.8
Both engines have the same parts available. the 5.8 is just a bit bigger at 351 cu inces over 302 cu inches.
John
Old 07-17-2001, 06:25 AM
TallPaul's Avatar
TallPaul
TallPaul is offline
5.0 or 5.8
The 5.8 has a lot more power! Which translates to fun! They both should be fairly durable as the 5.8 has proportionately beefer bearings than the 5.0 (according to a Ford engine manual I consulted). The 5.0 probably can wind out a bit more as it has a shorter stroke. I believe they both have the same bore. As a stroker the 5.8 is pretty torquey.
pintoches
06-23-2011 04:05 PM
BigPapi
10-09-2009 08:53 AM
starweb
Washington Chapter
04-05-2009 12:39 AM
FortyFords
1999 to 2016 Super Duty
16
01-13-2003 11:10 AM
Quick Reply: 5.0 or 5.8
