Aerostar Ford Aerostar
fuel problem ??
Old Mar 8, 2005 | 04:02 PM
shamr0ck's Avatar
shamr0ck
fuel problem ??
hi I'm new to this forum, but I have a 93 aerostar 4.0 with a fuel problem. It's running rough and blowing black smoke. Changed the plugs, and still the same problem. I took it to a mechanic and he's baffled by the fact that it won't stay running long enough to run a diagnostic test , but it runs (rough) if he pulls the fuse on the oil pump ?? not sure why it would still run. thats the extent of whats been done and am at a dead end. Any suggestions would be appreciated. Thanks.
Old Mar 8, 2005 | 04:15 PM
copper_90680's Avatar
copper_90680
Oil pump fuse? I have never heard of one before. The oil pump on Aerostars are mechanically driven.
Old Mar 8, 2005 | 04:26 PM
shamr0ck's Avatar
shamr0ck
Wow, ok thats whats the mechanic said. Kinda scary. Could that be a bad fuel pump then?
Old Mar 8, 2005 | 04:50 PM
copper_90680
If he pulls the fuse on the fuel pump, the engine would quit after it runs out of gas. Are you there when he pulled the fuse? If so, can you describe where it was? I have a feeling he didn't pull the fuse, but just the plug that disengages the computer. That is a grey plug on a harness on top of the firewall, near the brake master cylinder.
From what you described, I'd say there are four most likely possibilities:
1) Your IAC valve
2) Your fuel pressure regulator
3) Your injectors are stuck open
4) If you are unlucky enough, Rbastado had pretty much the same symptoms and it was his engine computer that quit. That would really be a bummer!
By the way, I just had to ask. Are you sure the plug wires are on correctly? Sometimes, when people change plug and wires, they cross a couple of them and wham, car runs terribly or not at all with lots of black smoke and an occasional backfire. I have done that a couple of times.
Old Mar 8, 2005 | 05:10 PM
shamr0ck's Avatar
shamr0ck
Thats a possability that the wires were crossed but it was running the same before the tune up. I wasn't there when he pulled the (fuse) he just called and told me.He said with the fuel pump off it would stay running just rough. he sounds kinda clueless. I guess thats kinda scary seeing he's ASE certified specializing in fuel problems. however I appreciate your help. I'll metion these things to him and well- we'll see. Just tyring to get home to Georgia. Thanks
Old Mar 8, 2005 | 05:14 PM
aerocolorado's Avatar
aerocolorado
Hmmm.....him blow black smoke Kemosabe.....
.....you're right Tonto, he suffers from excess gas.......but ole' copper is hot on the trail. Let's leave the horses here and sneak up behind those rocks and watch what happens.......
(to be continued.)
Old Mar 8, 2005 | 06:25 PM
yendor's Avatar
yendor
Does this not sound like fuel pressure regulator or MAP sensor is unhooked from vacum
Old Mar 9, 2005 | 01:53 PM
shamr0ck's Avatar
shamr0ck
fuel problem ??
thanks for the help guys. $500 later it was the fuel regulator.
