advice needed
Old Feb 21, 2005 | 04:52 PM
buckcreek's Avatar
buckcreek
advice needed
yes i have a 95 f150 4.9 manual od with axle code 12 with 31's , the truck runs great but i have no pulling power as far as pulling a trailer . the gas mileage is 17-18 on the road, can someone give me an idea on what gears to help with this problem
Old Feb 22, 2005 | 07:11 AM
buckcreek's Avatar
buckcreek
surely someone has an suggestion on this problem
Old Feb 22, 2005 | 07:37 AM
Roushians's Avatar
Roushians
axel code 12 = 2.73 rear gear, which is excellent for highway cruising/speed/mileage, but very very bad for towing/acceleration.
you'd need to swap gears to get a higher gear (3.55 or higher i suppose).
I have no idea how much it'd cost and how long it'd take, as well as degree of difficulty.
Old Feb 22, 2005 | 08:53 AM
midlf's Avatar
midlf
It may be cheaper and/or easier to get an entire axle assembly from a salvage yard rather than changing gears.
Old Feb 22, 2005 | 08:57 AM
Mike G's Avatar
Mike G
Gears usually cost about $200 and then if you want them installed, it's about another $200, unless you have a 4x, then you need to double your estimate. Check with your local frame and axle shop, they can give you numbers better.
--Mike
Old Feb 22, 2005 | 09:05 AM
amish77's Avatar
amish77
I'm running a 77 f-100 with a 300I6, three speed, and I have a decent amount of pulling power. The motor is known for making a lot of low end torque but not so much in the way of horsepower. If the gears don't work, or you don't enjoy the idea of spooling your truck to oblivion, you could try a better intake/exhaust from some place like cliffy. It should free up a few extra hp for the same amount of dollars. The gears will definately get more towing power than what I'm suggesting, but they will cost you in the gas and highway rpm department.
Old Feb 22, 2005 | 05:16 PM
buckcreek's Avatar
buckcreek
thanks for the info guys , I m all ready running a k&n air filter and ture dual exhaust with no cats. but have not changed out the coil or the intion box and also is there a site that shows the air box mod?
Thanks
Old Feb 22, 2005 | 05:48 PM
tex94F250's Avatar
tex94F250
Arrow True duals, no cats, on a 300-6 cyl. Torque anyone?
Well, if you're running a true dual exhaust system on your 4.9l I-6 and 31" tires I'm surprised that you have any torque at all. As Roushians posted, you need gears, per the formula based on a stock 27.5" diameter tire and your 2.73 diff your actual final gear ratio is now 2.38. There is probably no back pressure, which is necessary to develop torque, does it get out of it's own way? One of our yard guys has an '96 F150 with a 4.9l and it will pull the earth off Atlas. They can be one stout engine, and probably the most under-rated engine Ford has ever put in a truck. I think it is probably my favorite engine after the 460 for brute torque, and so easily modified for more. Re-think the avenue of mods you've taken, you're gonna spend a lot of money, not be emissions legal at some point, and not realize the tremendous ability of the engine.
Old Feb 22, 2005 | 05:55 PM
buckcreek's Avatar
buckcreek
so what you are saying is I have hurt my truck by putting the duals on it .
what do you suggest putting under the rear I love the truck but just don't have any power to pull any thing.
Old Feb 22, 2005 | 06:35 PM
tex94F250's Avatar
tex94F250
At least a 4.10. The 4.10 with the 31" tires will calc out to a 3.72 +/- and you will operate in the power band that is most beneficial. The generation of torque is not the same as horsepower. Torque is the "grunt" in the motor, it's what get 'er done. What kind of muffler are you running? A true open breathing full flow low restriction exhaust will not help in the torque area and if you have true duals are they on headers, only setup I've seen for duals so far? Search the 300-6 forum for performance enhancements, there is a lot of beneficial information there. Good luck!
Old Feb 22, 2005 | 10:31 PM
SoCalDesertRider's Avatar
SoCalDesertRider
Tex is right on the money to recommend 4.10 gears. They will give you the towing power you're looking for. Your transmissions overdrive gear will take care of lowering rpms for highway cruising. 3.73's would also be a descent ratio if you don't want to go all the way to 4.10. That 2.72 ratio in it now is rediculus in a truck. I don't know why Ford even bothered offering it.
Using a junkyard axle in lieu of doing a gear change, the lowest (numerically highest) ratio you'll likely find is 3.55. Most 1/2-tons were 3.08 or 3.55.
Old Feb 23, 2005 | 08:11 AM
buckcreek's Avatar
buckcreek
calling the wrecking yards right now to see what i can find.
also has anyone changed thier injectors to the 19# ones and how did that work out for you.
thanks
