Help Identify Sensor
Old Feb 16, 2005 | 08:50 AM
dsheleg's Avatar
dsheleg
While removing my water pump, I noticed a sensor located just under the Alernator that was disconnected. It has a right angle, small gauge wire connector that connects to the sensor. It kind of looks like a temp or pressure sensor. I have not been able to find this sensor anywhere in my factory repair manuals......What's the name of the sensor?
I have a 1997 F350 crew 7.3L.
Any assistance would be appreciated.....
Old Feb 17, 2005 | 12:24 PM
dsheleg's Avatar
dsheleg
Anyone know what this sensor is??????
Old Feb 17, 2005 | 04:10 PM
1995Ford250's Avatar
1995Ford250
Not for sure, my guess is that it is coolent temp sensor.
Old Feb 17, 2005 | 09:20 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
There are only three sensors on the front of the engine. One is the coolant temp sensor on the water pump. Next is the exhaust backpressure sensor, which is attached to a small tube that comes off the passenger side exhaust manifold, and the third is the camshaft position sensor which is down low by the crank balancer.
